AMG 18" wheel
Old May 15, 2004 | 06:08 PM
budianto's Avatar
W210
AMG 18" wheel
Will AMG monoblock 18" x 8.5" offset 35 fits in to my e320 W210 ?
I think it used to be in the S500.
Thanks.
Old May 15, 2004 | 06:46 PM
E-Klasse's Avatar
W205 C300
All 4 wheels are 18x8.5 ET35? They will fit in back just the way they are. Up in front you might need spacers. The fronts are 18x8 ET31 and the backs are 18x9 ET35 for an E-Class. Better check the bolt head size is needed. The S-Class uses 14mm bolts and the E-Class uses 12mm bolts.
Old May 16, 2004 | 11:49 AM
Whitey's Avatar
98 W210 Advantgarde
That is bizzarre! Be careful!
The S-Class uses ET44 for 8.5" rims. If it had ET35's all round they would have looked a bit strange and yes, the bolts will be different. Are these genuine AMG or replicas?
IF everything else checks out, 8.5" ET35 would make the rears noticeably stick in behind the fenders further than the front but this can be fixed with 5-10mm spacers. In any case 8.5xET35 is a common/standard setting for 8.5" wheels for the E, just won't look as good as they should without the spacer adjustment.
Old May 16, 2004 | 04:55 PM
budianto's Avatar
W210
Thanks for the reply ... i'll double check with the seller. He told me it's original AMG from s500.
Old May 16, 2004 | 05:52 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Re: That is bizzarre! Be careful!
Old May 16, 2004 | 07:29 PM
Whitey's Avatar
98 W210 Advantgarde
Jimmy, sold? WTF, so quick! I guess its congrats....
Old May 17, 2004 | 11:04 AM
Thanks mang, it turned into a slight bidding war, had over 40+ responses in 24 hours, lol...
