Correct Tire Pressure for Bridgestone S03 on CLK 500
Old May 18, 2004 | 02:38 AM
TheRok's Avatar
W209
I changed the wheels from the stock 17” to 18” with tire sizes of the following:
235/40/18
265/35/18
The tires are Bridgestone S03 pole positions.
What is the correct tire pressure for these tires on a W209? The stock Pilots that came with the car recommend 35 psi (F) 38 (R)
Thanks in advance for your help
Old May 18, 2004 | 11:39 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
35 front and 38 rear would be fine because even though you changed the tires you didn't change the weigh tof the car
