How do you calculate offset?
Old May 26, 2004 | 07:27 AM
C32Andy's Avatar
2016 C300
Please provide some professional info.....thanks
Old May 26, 2004 | 08:46 AM
Brunelleschi's Avatar
In the market
I am going bump this to the front because I would kind of like to know as well.....
Old May 26, 2004 | 10:06 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
reading the tech thread at the top of the page you would find this info:
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
Old May 27, 2004 | 11:30 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Wheel Offset Calculator:
www.mindspring.com/~toy4two/offset.html
