Offset Question.....
Old Jun 9, 2004 | 12:24 PM
Stich's Avatar
I was wondering if you guys can tell me if these offsets would fit a 2003 W211 E500.
19 x 8 with a +34 offset and a 19 x 8.5 with a +26.
Thanks for the help in advance.
Old Jun 9, 2004 | 12:57 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
a better fit would be 19x8.5 ET25 - 35 and 19x9.5 ET 30 - 35
the size you listed would most likely fit but, i would verify that the 19x8 has enough load capacity
Old Jun 9, 2004 | 02:29 PM
Stich's Avatar
The 19 x 8 for the front has a high disk wheel pad so i think it should fit over stock brakes. The face of the rim is pretty flat.
But you think the rear for sure should fit without a problem?
