Wheel Bearing is it adjustable?
Old Feb 5, 2019 | 03:16 PM
DB-MB's Avatar
C220 CDI w204
Thumbs up Wheel Bearing is it adjustable?
Hi,
MOT advisory -Wheel Bearing slight play - is this adjustable on the w204 2013 C220? I heard some Mercedes this could be solved by adjusting rather than replace?
any Advice or directions to video tutorials of the same?
Thanks in advance
Old Apr 3, 2019 | 08:13 AM
TechSuperstar's Avatar
15' CLS400
Yes, they are adjustable and very simple, but note you can damage the bearing if you go to tight (head, friction, etc.). Maybe start with a single turn clockwise... After adjustment turning the rotor by hand you should feel tension but after you put the wheel on it should be able to spin otherwise you've gone to tight.
Video:
