S212 uneven back suspension.
Old Sep 12, 2020 | 09:55 AM
art wood's Avatar
s212
Hi All,
I have a problem with rear air spring after changing them.
Basically the rear was dropping down in every 2 days so I decided to change both springs, firstly I have change block valve but it didn't help ( well it did but only for a week then is dropped again - quite weird)
Then I had changed springs but after that right side it's went to the certain level and stopped at the same time left side went much higher.
I decided to change level sensor, I did a calibration with xentry but it is still the same, left side go higher than right and I can't change that even manually with xentry.
I am wondering if any of you had that issue?
Artur
Old Oct 12, 2020 | 12:45 PM
art wood's Avatar
s212
Hi Again,
Small update. Car still behaving same but I found some fault code.
1. Compressor is running to long ( possibly because it's trying to pump it up to right level but something is not allow it)
2. A19700 (B219700) [Stored] The power supply of circuit 30g ( I read about it a little and apparently fuse box f32 needs replacing)
Did Any of you have similar problem,
Do you thing that fuse box can cause the problem?
Artur
