W213 The air suspension left behind
Old Jan 15, 2021 | 09:28 AM
bickham's Avatar
E220 W213 station wagon 2017
Have problems with my E220 W213 number plate CR70087 122000 km.The air suspension left behind drive up and down, if I press the level button the car rises 25 mm and then it stays still, when I press the level button again the suspension starts running up and down again, when I stop the engine the airbag stops movingitself, left behind collapses after 2 nights.There has been professional listening equipment on all joints and air bellows and there was no leakage.I have just replaced the left front air spring leg / hose and the valve block.Where do the hoses run to behind the springs outside or inside?Is there anything to calibrate when components in the chassis have been replaced?Hope you can help me.Thanks in advance and best regards Jacob Bickham
