My 2018 GLC300 with 30,000 miles is exhibiting front rotor warped symptoms. I am debating whether to just have the OEM rotors turned or replace them with new ones. If I replace the rotors, I will likely replace the pads as well.
Has anyone had this issue and replaced rotors? Did you replace pads as well? Did you use MB parts or go with Aftermarket? If aftermarket, what brand did you use?
Thanks for your input.
Currently Active Users (1)
