Aftermarket Rims Don't work with stock bolt/lug nut
Old Feb 3, 2022 | 10:26 PM
mikster's Avatar
C300
So I bought a set of aftermarket 20" wheels for my 2018 e400 coupe from a guy that had it on his CLS. When i mount the wheel on the car and tighten the wheel lug/bolt down to the max the wheel is still loose and wobbling. I have bought many aftermarket wheels before and had never had this problem before....all my stock lugs would always work with any wheels that i bought. This is common? Do i need to buy a different bolt/lug??? The wheel isn't compatible with my car?
Thanks in advance
Old Feb 3, 2022 | 10:40 PM
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
It all depends what the after market wheel manufacturer recommended with their wheels. It could be Spherical or Conical seat lugs and it's the way they sit in the lug holes. You can either call the previous owner and ask him to send you a picture of the lug bolts to compare with yours or call the wheel manufacturer
Old Feb 7, 2022 | 06:44 PM
Siegmann's Avatar
10-second E550
You need conical lug bolts for the aftermarket wheels. Factory wheels are ball seat.
Old Feb 13, 2022 | 08:22 AM
streborx's Avatar
Top Answer: 1
G550
Go back to the guy that sold you the wheels and ask him for the lug bolts that probably came with the wheels when he bought them. If they're the wrong size for your vehicle, contact the wheel distributor for a set.
Old Feb 20, 2022 | 09:57 AM
Gordp's Avatar
2018 E400
Various rims from Mercedes / AMG and other vendors are of different thicknesses where they bolt to the hub. Therefore the lug bolts from the standard rims are the wrong length and need to be replaced with the correct length matching the rim thickness. Pay attention to be sure to get the correct seat type (ball, conical, taper cone or?) or they won't lockdown.
