Raise or lower Tire Pressure
Subscribe
Mar 8, 2022 | 06:24 AM
I read conflicting information about this. My 19" all season run flat tires on my s coupe give me too stiff a ride. They gas door says 33 front, 34 rear. If I do stick with these tires, how do I soften the ride -raise the pressures or lower them? In 45 years of driving, I always thought raising the pressure gave you a stiffer ride. But, some here say otherwise. Any help would be appreciated.
Reply 0
Mar 8, 2022 | 07:43 AM
more pressure makes tire less forgiving since when you hit holes in the tire it deforms inward increasing the internal pressure which acts like a spring to "bounce back"
SO with more pressure to start your tire "spring" is stiffer
Reply 0
Mar 9, 2022 | 06:29 AM
I've never read anything positive about run flat tires. MB regards a flat tire event so unimportant and unlikely that G Wagens aren't even equipped with a matching dimension spare tire. Buy a set of conventional tires and be sure you know how to use the jack and lug wrench.
Reply 0
Subscribe
Currently Active Users (1)
