Pop quiz - brake lines, exhaust flange, oil pan
1. first picture. the Brake lines are Rusty and starting to flake, to replace $3100.00, These lines run thru the body of the vehicle.
2. The exhaust flange 2nd picture is cracking, to replace and do a Weld repair $1050.00
3. 3rd Picture is your Transmission pan. The rust is starting to bubble & flake, To change the pan with the Transmission Service $610.00
and also without pictures -
Your rear brakes 95% worn, Pads, rotors and Sensors $710.00,
Recommending replacing the Drive Belt $230.00. Please give me a call
The question is: How much of this work would you authorize??
Henry
