need help with psi for my new rims and tires
Old Oct 9, 2004 | 07:10 PM
carmos's Avatar
2004 c230 sedan sporte
hi all,i need to know the psi is for 235/40/18 on 18's by 8.5..should the pressuer be the same in front as an in the rear? the tires are falken ze 512 i went there site and the only show the cold maxiumum ..any help would great thanks.. p.s. i have the same size rims and tires in front and rear...
Old Oct 9, 2004 | 08:06 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Luke from the tirerack recommends that you use the settings suggested by MB. It sounds strange due to your upgrade. But he posted this wisdom on several occasions. HTH
Old Oct 10, 2004 | 11:00 PM
carmos's Avatar
thanks for the info amdeutsch
i tried that and it seems to bounce a bit lees with the new tires set to the stock 28 front 32 rear psi..
