Fitment issue BBS RE-V7 007
Old May 29, 2023 | 10:19 PM
Ryan’s's Avatar
2023 E450 4matic sedan
I decided to buy set of rims mentioned above. These are my vehicle’s specs : 2023 e450 4matic sedan with air-suspension.
Squared/ 18x8.0/ 5x112. I’m a little concerned about fitment since I can’t seem to find the offset. Those rims apparently 18x8.5/ 5x112 with +42 offset. Could you guys help me out here? I can get center rings but don’t know how to find my oem offset
Old May 29, 2023 | 10:55 PM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
You can always take one of your tires out and read the offset written inside the wheel. Here is your car wheel spec sizes:
https://www.wheel-size.com/size/merc...50-4matic--362
Assuming you have 18x8 ET43 OEM, 18x8.5 should be around ET48 OEM, so it should normally fit with ET42 as long as it clears your brake calipers.
