W204 brake wear sensor question
Old Sep 23, 2023 | 04:25 AM
IndyRob63's Avatar
C350 Sport Sedan
The “Check brake pad wear” warning message came on in my 2014 C350 right when I turned over 75K miles. From researching the cause of this message online I was under the impression that this was triggered by a wear sensor located in the pad (passenger front on my car). My understanding was that there is a sensor pin that is inserted into the pad on install and when the pad wears down to the depth of the pin, it causes it damage which changes the resistance and triggers the alert message. I purchaed new pads and rotors and installed them yesterday. However, when I removed the old ones there was still at least 1/16” or more depth on the pad with the sensor before the pin would have been touched. The pads had quite a bit of wear left (I drive mostly highway miles) so I was surprised I had gotten the alert.
Am I wrong about how this system works?? I went ahead and replaced the pads and sensor and rotors since I was in there anyway…
