Spacer Questions
Old Nov 18, 2004 | 12:13 PM
Nefarious's Avatar
'01 C240 6spd
Spacer Questions
I was told by a shop that the 10mm H&R spacers he had would work on the rear of my W203 but not the front. Any idea why this would be?
Any idea where I can get some spacers that will work in the front ASAP?
Old Nov 18, 2004 | 12:27 PM
Brunelleschi's Avatar
In the market
I think they may be different spacers between the front and rear on this car. I have the 10mm spacer on the rear of mine, but the diameter of the hub was a little to big for the same spacer to fit on the front. As of now I have a generice spacer on the front, but I am not at all happy with it. It works, doesn't fit very snuggly and if you don't have it perfectly aligned when you mount the tire, you will get a little front end shimmy at higher speeds. As a quick fix though they are great and are only about $10. You can get them from NAPA.
Old Nov 18, 2004 | 01:48 PM
Nefarious's Avatar
'01 C240 6spd
Thanks. I'm gonna give the NAPA ones a try just to figure out if I actually need 10mm up front.
Old Nov 18, 2004 | 02:17 PM
In the market
No problem! That is exaclty what I did!
