03 s430 4matic air suspension
Old May 14, 2025 | 01:07 PM
S430 875's Avatar
Just got new s430 my first mercedes im prepared for the price but want to try and save money. I air suspension code c1517-001 critical level at front and rear axle) 002 032 (stabilzing times are too large) 064 (front left and right pressure diffrence is too large) I dont hear any leaks the bags dont really fill the compressor makes a noise for about 3 seconds then stops I assume its the compressor but i just need advice on what and how to test i got a good scanner i can do tests with thank you very much.
Old May 15, 2025 | 10:58 PM
smgak's Avatar
C230K
Lift the car and inspect for leaks.
Use your scan tool to activate the compressor and see if it’ll function for more than three seconds.
Old May 17, 2025 | 01:23 AM
S430 875's Avatar
I used my scanner it said the compressor takes too long to fill the bags and i tested the damper vavles all read 500miliamps whatever measurement it is and all were good exept vavle 1 on front right read 0 so I got a new compressor new vavles filter for it I was also woundering what would cause the bags psi to be uneven I got that code as well I also used the scanner to inflate deflate the bags and when I did it testing all 4 up and down it did not do anything at all
