Will these wheels fit my GLE450e?
Old Sep 2, 2025 | 11:25 PM
mikeylikesit50's Avatar
Have a 2025 GLE450e with 21 inch wheels with following specs:
275/45ZR21 10Jx21 ET54.6. Front
315/40ZR21 11Jx21 ET49. Rear
Found a good deal some 20" wheels with Pirelli Scorpion Winters 275/50/20 that came off a 2023 GLS Wheel part # 1674015000 with following specs. 8.5Jx20 ET62.6
When I run the calculator I get this:
Front:
https://www.willtheyfit.com?q=QVQfQ1...D0ZTQl0RFVc%3D
Rear:
Is this a reasonable setup?
Old Sep 8, 2025 | 01:12 PM
Alexie's Avatar
Those 20" GLS wheels are not a good fit for your GLE450e.
The offset is way too high (ET62.6 vs your ET54.6 front / ET49 rear). This will push the wheel too far inside the wheel well, likely causing it to hit the suspension or strut.
The width is also significantly narrower (8.5J vs your 10J/11J). The tires will be stretched and the wheels may not clear your brakes.
I'd pass on this deal and keep looking for wheels with specs much closer to your originals.
