20mm V. 35mm
Subscribe
Dec 15, 2025 | 10:20 PM
I went with the less popular 20mm. I heard this makes the wheel sit further out, which is what I want. I also heard 20 might have a deeper lip, which is what I want. Did I make the right choice?
Reply 0
Dec 16, 2025 | 06:37 AM
what are you talking about?
Seems like this belongs to an existing thread to understand what you are discussing... I am guessing backspacing but way more info required.
Like what car and stock wheel size etc.
Reply 0
Dec 18, 2025 | 08:09 PM
Wrong. The smaller the offset, the further out the wheel sits. A 20mm offset pushes the wheel in compared to a 35mm. If you want a deeper lip and a more aggressive, flushed look, you usually want a lower offset number. You might have gotten it backwards.
Reply 0
Dec 18, 2025 | 08:14 PM
Quote: Wrong. The smaller the offset, the further out the wheel sits. A 20mm offset pushes the wheel in compared to a 35mm. If you want a deeper lip and a more aggressive, flushed look, you usually want a lower offset number. You might have gotten it backwards.
Not according to Google AI. Can someone confirm?
Reply 0
Dec 18, 2025 | 08:19 PM
20mm vs. 35mm offset in wheels means the 20mm offset wheel sticks out further (wider stance) and sits closer to the fender edge, offering a more aggressive look, while the 35mm offset tucks the wheel further inside the wheel well, closer to the suspension, providing a more stock or tucked-in appearance, with the 35mm offering better clearance and less strain on bearings compared to a very low offset.
Reply 0
Subscribe
Currently Active Users (1)
