Where to get front bolts for W202 Camber Adj.
Old Jan 24, 2005 | 12:12 PM
Tank7's Avatar
2017 GLC 300 Coupe'
Just had alignment after lowering and the left front camber is -1.8 degrees and right front is -1.3 degrees. Both out of spec per the alignment shop.
Am I correct that there are new bolts that can be installed to correct this? I would need part numbers and where to buy as the local dealership has NO Clue (their main line is Buick and they only have one MB tech). Eibach does not make a set for this car, already tried.
TIA
