Spring pads
Old Feb 12, 2005 | 12:40 PM
midget fidger's Avatar
E550 Coupe
Spring pads
I saw someone over in the W208 area say that they changed the spring pads to even out a height difference between the front and rear. Would changing the spring pads cause any difference in ride quality? What do these pads do?
Thanks a lot!
Old Feb 13, 2005 | 05:13 PM
str8ridin's Avatar
05 E55
Thanks a lot!
It shouldn't change the ride quality. Each pad has about 1/4 inch difference, so they will just lower/raise your car depending on which number you get. Each pad is about $3 from the dealer. They are the black rubber things that sit at the very top of your spring and hold it in place.
