Audi & VW 18x7.5 wheels + tires. Price REDUCED!! ($495)
R350
These are great looking wheels. Give your ride that personalized, yet understated and sporty appearance.
Flik Wasp (gloss Black)
PCD: 5x112
ET: 33
Weight: 22lbs
Fits B5 A4's and a variety of Audi & VW models.
Tires:
x2 Michelin Pilot Sport PS2's with ~70% thread remaining, minor camber wear.
x2 Hankook Ventus HR-II with ~20% thread remaining, moderate camber wear since my car was lowered.
The wheels are in GREAT condition. There are minor scratches & chips associated with everyday wear. There is also a shallow ~2in curb scuff, but no defect can be seen without a close-up inspection. One wheel is slightly bent on the inside (picture available upon request) due to hitting a pothole. This does NOT cause any leak, and technicians at a local wheel shop balanced the wheel without problem.
I am stating every single imperfection, so there is NO surprise. You WILL be very satisfied with your purchase.
DYI on how to fix that curb scuff
http://www.bmwtips.com/tipsntricks/w...uff-repair.htm
Asking $495 with used lugs + lock & hubcentric rings for B5 A4's (this set was $1200+ new!!). Local transaction preferred, will meet buyer within reasonable distance. I am in Charlotte, NC.
PM for contact info. Negotiable!
Call 919-491-7007. Ask for Johnny.
See my Craigslist post for pictures. http://charlotte.craigslist.org/pts/316108883.html
PCD: 5x112
ET: 33
Weight: 22lbs
Tires:
FYI: If these are spec'd exclusively for VW/Audi then the center bore will be too small for MB.
Basically:
- MB wheels will fit VW/Audi (using hub ring shim)
- VW/Audi wheels won't fit MB (because center bore is too small)
Basically:
R350
MBworld Guru
white and whiter
read that you said you have the hubring that goes with the wheels. If you do need the hubring to put those on your car just find out what's the centerbore. In a lot of cases they have big centerbores which means other people just need hubrings.
good luck with the sell.
