FS W211 AMG E55 Rims and Tires
Porcelain Bus
Excellent condition W211 E55 AMG factory rims originally from a 2005 E55 and used as a spare set for my car which is at lease end. As you and see in the pics, there are minimal scratches on the lips and only one rim has minor curb rash. The tires have a little life left but are down to the wear bars. These should fit E class vehicles from 2003 on and SL class from 2003 on as well. Based on the similar offsets, they will probably work on earlier E's and SL's too, but you'd have to confirm this. They may fit other models as well. Tires are BF Goodrich G-force Sports. Rim data:
Front Wheels: 8X18, offset 30mm, tire(245/40ZR18) Mercedes part #:A2114012602
Rear Wheels: 9X18, offset 39mm, tire (265/35ZR18) Mercedes part #: A2114012702
Shipping charges will be the actual charges from Fedex Ground. You can calculate them by going to Fedex.com and using my zip as 33418. Fronts are 45 lbs 25 x 25 x 9, rears are 50 lbs 25 x 25 x 10.
Asking $750 plus shipping, add 3% for paypal.
