Sponsored by: MB Part Haus
W204 10mm Spacers with Lugbolts. CHEAP
Old Dec 29, 2008 | 01:08 PM
Derspeed's Avatar
X3 and 2012 C coming soon
Hi Guys. I am selling two 10mm H&R hubcentric spacers with 10 appropriate lug bolts. I installed one side and found it to be a bit too wide for my taste. After I installed that side, I had to remove it using a punch by going through one of the small holes in the face of the wheel. They are a snug fit. That is why there is a slight gouge in the face of one spacer (see photo). It has no impact on the fit or performance. I paid $160.00 for the set. I'd like to sell it all for $80.00 plus $15.00 flat for shipping anywhere in the lower 48. I am open to offers, but this is quite cheap. The spacers are part#2055665 and the bolts are 14x1.5. In the photos you will notice some smear marks on the spacer that was installed. Not to worry. It's anti-seize grease. I never install wheels without it. I'm pretty sure they will work with C63s as well. I believe all W204 wheels have a 66.5mm centerbore. H&R is closed until 2009, so I could not confirm it.
I'd like to sell this week. Please excuse the mess in the garage.
Old Dec 29, 2008 | 01:33 PM
hutch300's Avatar
2022 GLE450
would they ever rub?
Old Dec 29, 2008 | 03:12 PM
Derspeed's Avatar
With the 18" AMG wheels you'd have to compress the OE springs so much that the tire would tuck enough to let the outermost bulge in the tire sidewall rub the inner fender. It may not even happen then because of the direction the tire travels due to the independent suspension. Just driving down the road, the tires will not rub. Hit a huge bump; I am not sure.
