wtb: 7mm lorinser spacers and bolts
1994 e320, 1990 jaguar xj6 sov
hi;
am looking for a set of 7mm lorinser spacers for d93 wheels
wheels are going on a 94 e320
bought the wheels (16x8 et 44) and only had one spacer in a bad shape
if hub centric rings and the shorter bolts are available also for back and front that will be great too
paypal ready
thx in advance
ronnie
paypal ready
thx in advance
ronnie
12mm
the wheels are going on a 94 e320, from the fitment guide on the w124 forum, for 16x8 the offset should be 34/35
so am not sure if 12mm will make them stick out too much or cause rubbing?
any thoughts?
any thoughts?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
7mm or 10mm
thanks for checking,
i have one lorinser spacer that was on one of the wheels that says ATG for lorinser, but the center is bigger (almost 72mm), i wonder what car that would fit?
the search continues for spacers
custom spacers
almost giving up on original lorinser spacers
thinking of getting a couple of custom made spacers for the front
10mm hubcentric ( they call it Hub Centric to Vehicle and Wheel Centric to Wheel) for $115 shipped
the spacers will be 10mm, center hub bore 66.56mm and wheel center 82mm
adding the link for feature searches
http://www.motorsport-tech.com/4DCGI/s_centerbore.html
does this sound like a good deal?
Um again, I have factory Lorinser spacers available in two sizes. 17 will give you a better "stance" with less of a tucked in appearance of the wheel. (Not to mention the increase lateral grip and decrease in understeer if for the fronts)
Also, factory lorinser spacers bolt onto the wheel for a tight filament so you can balance the wheel with the spacer on.
SL
Realize 8in with 17mm would be the same (actually less) as 7mm and a 9in wheel assuming same offsets.
I would just compare the offsets with the widest wheels you know fit your car:
http://www.1010tires.com/WheelOffsetCalculator.asp
Note: Spacers decrease your offset by their size (ie 10mm will decrease your offset by 10 so 44 would now be 34, etc)
If your outside wheel position with spacers is less then the outside position of the widest wheel, you know you will be ok. (I hope that makes sense?)
2002 CLK 430/2002 325i
I found a pair of 10mm spacers
I was cleaning out my garage and found a pair of 10mm spacers made for an E-class. They do not include the bolts. Let me know if you are interested.
