FS Authentic 19" Stagg. Brabus Monoblock VI 2pc
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Is there anyway you can post the offsets ? Did you use any spacers on the CLK ? There are numbers on the back of the wheels they are stamped , they start with the letters ET ... or you can call Brabus and give them the serial numbers and they should give you the offsets . Ia m very interested but must know the exact offsets before . would you remove the tires if someone was to buy the wheels , I am assuming that since you didnt mention the brand of tires or the tread depth .. that they are quite used , that means they will only add extra weight . Please let me know . Thanks,
