FS: 22INCH ASHANTI WITH TIRES
2001 cl500
HELLO ALL THANKS FOR READING. UP FOR SALE IS A SET OF 4 RIMS AND TIRES. THE RIMS ARE MADE BY ASHANTI. PLEASE DO UR HOMEWORK ON THE RETAIL OF THESE RIMS. THESE ARE HIGH END RIMS. THEY COST 8,000 DOLLARS NEW. PLUS 1000 FOR THE PIRELLI TIRES. ABOUT THE RIMS. THEY ARE ON MY MERCEDES CL500. I BELEIVE THE BOLT PATTERN IS 5X114 OR 5X112. ILL HAVE TO DOUBLE CHECK. THESE RIMS ARE 8.5 WIDE ALL THE WAY AROUND. THE REAR HAS A SLIGHTLY BIGGER LIP, BUT YOU CAN STILL ROTATE THE RIMS AND TIRES FOR EVEN TIRE WEAR. WHEEL LOCKS(20) AND KEY COMES WITH THESE. ALSO THERE IS SOME AFTERMARKET TP MONITORS ON THEM. YOU NEED THESE FOR CHECKING TIRE PRESSURE WITHOUT A GAUGE. THEY COME WITH ALL MATCHING PIRELLI P-ZERO TIRES. THE SIZE IS 245/30/22. THEY HAVE AT LEAST 40% TREAD LEFT.
THE BAD: OF COURSE WE ARE NEAR DC. SO 2 OF THE RIMS ARE BENT. ONE HOLDS AIR, THE OTHER LEAKS AIR. I PUT AIR IN THAT TIRE, EVERY OTHER WEEK.
THE GOOD: I KNOW OF 2 GREAT COMPANYS THAT WILL STRAIGHTEN THE WHEELS FOR ABOUT 100.00 DOLLARS EACH. ONE COMPANY WILL PICK THEM UP, THE OTHER YOU HAVE TO DROP OFF.
IN CONCLUSION: THESE ARE GREAT RIM AND TIRE PACKAGE. IM SELLING THESE FOR DIRT, DIRT CHEAP. IM DOWNGRADING TO 18INCH, TO PREPARE FOR SALE. IM SELLING THEM CHEAP BECAUSE OF THE BENDS. YOU CAN GET THE RIMS REPAIRED, AND HAVE A AWSOME SET OF WHEELS. THERE IS NOT ALOT OF ROOM FOR NEGOTIOATION. WILL CONSIDER ALL TRADES OF VALUE. PREFREED GUNS (LEGAL THAT I CAN SWITCH TO MY NAME, MUST BE IN YOUR NAME). YOU CAN CALL ME AT 301-257-7945. THANKS JEFF I KNOW THEY FIT CL AND S. PLEASE DO HOMEWORK FOR OTHER FITMENTS.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
