Sponsored by: MB Part Haus
FS: Lorinser D93 17" x 8"
Old Sep 22, 2010 | 12:06 AM
Sincity's Avatar
These are quite rare nowadays and a set seldom shows up on eBay. The set is very clean with the exception of one wheel that had a little clear coat peel (touched up with clear and very subtle) and one with slight curbing. For those that do not know about Lorinser wheels, you must use their spacers. These started with a base et of 44. I have 2 12mm spacers and 2 7mm spacers. Also included is the center cover locking wrench. Total offset is 35 for the front and 32 for the rear. You will need to purchase different Lorinser spacers if you are not happy with the offset that I have.
I will not be able to ship these until after Oct 1 as I am waiting for my other wheels to arrive.
TIRES ARE NOT INCLUDED
Looking to get $495 + shipping
Pics:
RF wheel. Clear coat chip is on the edge of the rim around the 3 o'oclock position. And that is with the bright Vegas summer sun hitting it. Otherwise, almost unnoticeable.
RF wheel. Closeup of the clear coat peel that has been touched up.
RR wheel. Curbing is at 12 o'clock position. Dark spot is shadow from tree.
RR wheel. Closeup of curbing.
LF wheel. The best of the set.
LR wheel. There is a small chip at 12 o'clock from tire mounting equipment. Second to best.
Old Oct 2, 2010 | 01:38 PM
Sincity's Avatar
SOLD
Old Oct 5, 2010 | 12:03 PM
tap400E's Avatar
1993 400E
Hey Sincity the wheels fit perfectly! I used your spacer set up... 12mm for the fronts and the 7mm for the rears.
Thanks again for the great deal!
Attached Thumbnails FS: Lorinser D93 17" x 8"-lorinserd93tap400e.jpg
Old Oct 5, 2010 | 12:26 PM
Sincity's Avatar
Looks great and I'm glad they worked out for a local! They looked better with the face-lifted cladded models like yours. I'm just curious how come you didn't use the 12mm in the rear instead? You would want the rears to stick out further than the fronts.
Old Oct 5, 2010 | 12:52 PM
tap400E's Avatar
1993 400E
The 7mm spacers would not clear the larger front brake calipers. This spacer set up for front and rear cleared the calipers with about a 1/2 inch...
Old Oct 5, 2010 | 01:06 PM
Sincity's Avatar
I see. Too bad I sold my other pair of 12mm spacers. Check around because sometimes I see various thickness Loriners spacers for sale. Try not to buy new because I think they are like $200+ a pair!
Old Oct 5, 2010 | 03:01 PM
97W202's Avatar
2006 C230 6speed/14 C63
would carlsson spacers fit? I just sold a set of 12mm to a member for $50 I have a pair of 16mm. let me know
