Sponsored by: MB Part Haus
18x8.5 Brabus Bullit reps for W204-W212 $529 NEW
Old Jul 5, 2011 | 12:18 AM
powerwheelspro's Avatar
Former Vendor of MBWorld
E320
Description: One set of 4 18x8.5 Brabus Bullit reps
WHEEL SPECIFICATIONS
Size:
18x8.5
Offset: 48mm
Weight: ~28lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: Matte Black
Shipping: $85
FITMENT:
W204 / W212
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards. Obvious exclusion is curbing, denting or any other misuse that can damage or etch the finish such as use of strong chemicals in the cleaning process.
Manufacturing Defect Warranty: The wheels are made utilizing the low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarrantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
DISCLAIMER: The pictures of the car below were found online, they do not show our wheels and they are used for reference, to help visualize the look of the car with our wheels on. The pictures of the wheels alone are the actual wheels for sale.
Old Aug 12, 2011 | 08:00 AM
E320
Here are some pictures of the wheels on a W204 courtesy of Bayou Benz:
Old Aug 12, 2011 | 09:19 AM
Ducatinicolo's Avatar
CLK 500 Brabus
Can you give me a quote with those in black with a set of all season's or winter tires? Also, do you have brabus center caps by chance?
I have an 03 CLK 500 Brabus
Please PM your pricing. If you can give me multiple options with tires that would be great.
Thank you,
Nic
Old Aug 12, 2011 | 10:43 AM
E320
Thanks Nic, pm sent.
