Sponsored by: MB Part Haus
H&R spacer on wheel with centering ring?
Old Jun 13, 2012 | 10:34 PM
mmatrix's Avatar
is the spacer hub same shape and size as the original hub?
the stock wheel can fit on the original hub and it also fit on the spacer hub so...
is it possible to fit?
i came up with this
Old Jun 13, 2012 | 10:44 PM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
H&R are hub centric .. yes the hole in the center of the spacer is a hair larger than the hub , it fits snug .. but there is dust cap at the end of the hub, rounded off a bit , the inside of the hole of the H&R spacer is angled so that the lip on the exterior face of the spacer matches the hub, so that hub centric wheels can fit right . Hopefully that makes sense .. best way is to see one and fit it on a hub
Old Jun 13, 2012 | 11:18 PM
mmatrix's Avatar
Thanks!
will give it a try, many people are selling spacer but it get sold quite fast, it like a HOT item.
im looking for either 10mm or 12mm for the rear,
i checked H&R, other than SUV merc, the rest 1990 onwards all have the same part number.
Old Jun 13, 2012 | 11:35 PM
maxwerks's Avatar
The get sold often because people change wheels all the time ... if they had wheels that required spacers then next set of wheels may not , or may require a different thickness , so they sell them ...stay with H&R s though .. they are not that expensive brand new , and it is not one of these items where one should skimp on ...
