FS: BBS LM-R 19x8.5 Authentic
E320CDI, CLK55, and a Smart
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
I had these on my W211 E320 CDI
The bolt pattern is Porsche standard 5x130 but I had custom adapters/spacers machined to make these work on a 5x112 mercedes or audi with the proper centerbore to fit the hub. I ran these on 245-35-19 tires and they fit perfectly. One of the wheels has a small curb rash about 1 inch. They are all washed inside and out with very little brake dust baked on. They are used but in excellent condition. No tires included. Black centercaps included.
Specs on these specific wheels.
Offset: 55mm
Backspacing: 6.97"
Bolt Pattern: 5-130
Weight: 23.5lbs.
Tirerack lists these for $1,255 each or $5,020 for the 4.
I am selling these for $3500 for the 4 wheels and wheel adapters/spacers.
Incidentally. I also have some near new 19x9.5 LM-R wheels that I am selling separately for $1,500.
If you take all 6 wheels ($3,500 + $1,500) I will knock off $250.
No shipping for now. Local pickup only with cash in hand.
Offset: 55mm
Backspacing: 6.97"
Bolt Pattern: 5-130
Weight: 23.5lbs.
Offset: 55mm
Backspacing: 6.97"
Bolt Pattern: 5-130
Weight: 23.5lbs.
Offset: 55mm
Backspacing: 6.97"
Bolt Pattern: 5-130
Weight: 23.5lbs.
