FS: W221 / W216 ADV.1 05 TS 22" Wheels and Tires
2008 S63, 2012 E550, 2005 E55, 2005 SL55, 2013 SL63, 2020 AMG GT, 1994, 1998, 1999, 2001 SL500
FS: ADV.1 Track Spec 22x9.5 front with 255/30/22 and 22x11 rear with 295/25/22. Matching set of Nitto NT555 tires with 565 miles on the tires and new 315 MHz TPMS sensors. Offset and sizing is custom to the W221/W216 bodies. Will clear AMG brakes. Set is coming off of my 2008 S63. This set came with my car along with the OEM 20" loose. When I went to have new tires installed, my tire tech and I noticed that 3 of the wheels had been repaired previously for bends in the inner barrel of the wheel. All wheels run true and balance out without issue and the repair marks are only visible when the wheels are off the car. 1 front does have a small amount of clear coat discoloration only visible from 2 feet away. After finding the wheels had been repaired, my intention was to have the inner barrels replaced and all of the wheels refinished. Estimates have run between $1500 ( replace inners and powdercoat entire wheel ) and $3200 ( replace inners and pvd/chromeplate entire wheel ) . Can be even less if you decide not to replace the inner barrels and just powdercoat them as is. Due to the issues with the wheels, I am selling them as rebuilders so the new owner can refinish to his/her liking. Set will be available for shipping around 2/20/15. ( OEM should be back from refinishing by then ) Asking $3500 for the set complete shipped to CONUS.
