Sponsored by: MB Part Haus
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels $549 *NEW* from PowerWheels Pro
Old Mar 26, 2015 | 12:22 AM
powerwheelspro's Avatar
Former Vendor of MBWorld
E320
Description: 18x8.5/9.5 BBS LM style wheels
We are excited to offer the LM style wheels in 2 finishes
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-pa208816_zpsfc8fcec8.jpg
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-pa208821_zps9462b4f3.jpg
WHEEL SPECIFICATIONS
Price: $549
Size: 18x8.5 Front 18x9.5 Rear
Offset: 20mm Front 27mm Rear / 35mm Front 38mm Rear / 45mm Front 38mm Rear
Weight: ~24lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: Silver with Polished Lip or Gold with Polished Lip
Shipping: $85
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards.
Manufacturing Defect Warranty: The wheels are made in a low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrations or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-pa208813_zps560f15af.jpg
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-pa208811_zps4bde1e6e.jpg
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-pa208810_logo_zps3f56351b.jpg
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-pa208809_zps37ae323c.jpg
Below are some pics we found online which are used for illustration purposes. These are NOT our wheels
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-image30152_zpsca94bf96.jpg
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-e63lm_zps2e084b96.jpg
18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-db_e55_ps01291_zpsb3750977.jpg18x8.5/9.5 20mm or 35mm or 45mm BBS LM Style wheels 9 *NEW* from PowerWheels Pro-db_e55_ps00391_zps95a54ef9.jpg
Old Mar 28, 2015 | 08:54 AM
mr_byers's Avatar
n
Can these fit a 2000 e430?
Old Mar 28, 2015 | 11:12 AM
E320
Hi mr_byers
The 35mm offset will work perfectly on your car. You can also use your stock lug bolts.
Vassili
Old Mar 29, 2015 | 08:52 AM
mcelroyx's Avatar
2005 C55
Will these fit a 2005 C55 AMG? If so, will my existing AMG center piece fit?
Old Mar 30, 2015 | 12:12 AM
E320
Hi there,
Thank you for the interest.
The 20mm should work fine on your car and clear your brakes.
Not sure if the AMG center cap will fit, the diameter of the center caps might be slightly different. I can try at he warehouse for you. We dont have the AMG center cap but I can try with the stock Mercedes one, I am assuming they are the same diameter. The wheels will ship with the red BBS center caps.
Please let me know if I can be of any further assistance,
Vassili
Old Mar 30, 2015 | 12:44 PM
m3j0n's Avatar
W220 V12TT Land Yacht / W211 E55 Estate
Originally Posted by powerwheelspro
Hi there,
Vassili
vassili, can you answer my PM when you get a chance. Thanks.
Old Mar 30, 2015 | 05:31 PM
E320
Hello m3j0n,
Apologies for the delay, we had a container come in today and we have been slammed. I did respond to your pm.
Thank you
