FS: OEM wheels & snows 18"
FS: OEM wheels & snows 19"
FS: 19" Snow Tire Package
Selling for a lucky friend who moved away from the snow.
4 OEM wheels & snow tires. Originally purchased for his 2014 S63AMG. Paid $4300 at the dealer. Wheels, tires & TPS sensors included.
Wheels are factor OEM
Rear are part # A 2224010602 9.5" X 19 offset ET43.5
Front are part # A 2224010502 8.5" X 19 offset ET36
Tires are Pirelli Winter 240 Sottozero series 2, run flat & have 8/32" of tread.
Rear Size 275/40/19
Front size 245/45/19
Front wheels have slight curb rash.
Asking $2200 plus shipping.
Rear Size 275/40/19
![](http://i256.photobucket.com/albums/hh170/euruwarren/mercedes%20wheels/20150324_230648_zps4ypqbyu9.jpg)
2014+ S63's doesnt come with run flats, and 18", all 2014+ S63's are 20" and non runflats, and they are 285/35-20 rear, 255/40-20 fronts, are you sure they were from S63???
Wheels did for sure came off a 2014 S63 & were special ordered from Germany through the dealer.
2014+ S63's do come standard with 20" wheels and tires. Here is what Mercedes website says. "S-Class models are not provided with a spare tire. Models without Extended Mobility tires are provided with TIREFIT sealant and a portable air pump". The dealer recommended 19" tires as they will fit over the larger AMG brake rotors & being a narrower tire compared to the 20" will preform better in snow. Also they said the TIREFIT sealant does not work well in the winter & that is why they also recommended the run flat tires.
