Mercedes-Benz AMG W219 CLS 55 63 19" Wheels & Bridgestone Potenza RE050A Tires
19" original Mercedes Benz amg wheels
in absolutely excellent condition
tires are with about 80 / 90% tread
• 4x 19" AMG wheel
• 4x 19" tire
• 4x center cap
Front wheels: OEM part number A2194011502, offset 25, 8.5JX19, tire (255/35ZR19 255 35 ZR19 255 30R19 255 30 R19 255 30 19)
Rear wheels: OEM part number A2194011602, offset 28, 9.5JX19, tire (285/30ZR19 285 30 ZR19 285 30R19 285 30 R19 285 30 19)
I have a set of AMG 19" Mercedes factory OEM wheels and Bridgestone tires for sale. These optional AMG wheels are staggered; the rear wheels are 1" wider than the fronts. This set was removed from a CLS55 AMG Mercedes. These wheels will fit both the SL, CLS and E-Class chassis. Please keep in mind that these are authentic Mercedes AMG OEM wheels. These German-made wheels and will update/dress up your Mercedes while improving the appearance and increasing the value.
As I mentioned above, the wheels will fit the below models but if you are buying for your E Class, you may need to put 245/35/19 tire on the front and a 275/30/19 on the rear as the 285mm tires currently mounted may be a bit too wide.
SL-Class R230 (2003-2009) SL500 SL550 SL600 SL55 SL65
CLS-Class W129 (2006-2009) CLS500 CLS 550 CLS63 CLS65
E-Class W211 (2003-2009) E500 E550 E63
Price $1200 USD
text only 6 o 4 ~ 2 2 9 ~ 4 8 zero zero
Vancouver, B.C. Canada
W220 W211 W219 E320 E350 E500 E550 E55 E63 CLS63 CLS55 CLS550 CLS500
