FS: Mercedes OEM BBS AMG SL600 Rear Wheels 18x10 5x112 ET25 Wt 28lbs 2 Piece $1000
Condition:
**As you can see both wheels seem to have had the lips painted and clear-coated. One of the wheels has the paint and clear chipped away showing the polished metal lip underneath which appears to be in excellent condition, but one can not be for certain unless taking down all of the paint from the lips.
**One (1) wheel has about a 10cm hairline crack in the barrel. It never leaked air when tested and it does not extend through the barrel, only the inner surface. Discussion with a few wheel builders have said that this can be fixed and balanced without issue.
**SO one wheel has the defects in the lip paint AND the hairline crack, the other wheel is in perfect condition.***
Specifics:
Manufacturer: BBS (Germany)
Diameter: 18"
Width: 10"
Bolt Pattern: 5x112
Offset 25mm
20 Titanium BBS Bolt in perfect condition per wheel.
Weight 28 pounds per wheel
PN: 1294001702
These wheels are considered the "holy grail" in some circles and are extremely hard to find. Unfortunately, I do not have the 18x8.5 front wheels to complete this set. There are no lug bolts or center caps included. After searching the country for another set of the rear 18x10 wheels, there are none for sale that I could source. Even sources such as wheel collision in Bath PA have neither the front nor the rear wheels for sale.
$1000 shipped for the two wheels in the CONUS via FedEx ground. Pick-up is available in Manhasset NY 11030. Paypal payment is accepted as a gift or if you are paying fees.
Defect in lip pain/polished metal underneath
Hairline Crack
