DIY Throttle Calibration?
2003 C320 Sport Sedan
Is there a DIY throttle reset? I heard it's been possible in other MB's, but can't find any info (searched already) for the W203's.
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
It's been posted before in other forums, but thought I'd add this to our DIY stickies.
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
Kwameskillz (10-16-2022)
2006 C230 2.5 V6
1 Post
C230 Kompressor sportscoupé (2001)
Brabus K3
Best Regards.
Too many to list
Originally Posted by rubensans
How do you know the reset was successfull?
Best Regards.
Best Regards.
'10 GLK350 4matic/ '05 BMW e46/'20 F-150 3.5L Ecoboost
Originally Posted by bxtc
What will excatly happen when you reset the ECU... Will the speeder respond be better if you drive the car harder the first 500miles?
2016 C63s AMG
Originally Posted by diamondblak05
Whenever I reset mine, I'll hear a "click" by the key hole exactly 3 minutes after I take my foot off the accelerator pedal. I've done this numerous times to see if it's consistent and it have been. I guess this must mean the reset worked. Otherwise, I have no idea or clue if it really worked.
Best Regards.
Best Regards.
when you press the gas pedal to the floor and hold for five seconds are you suposed to also press the quick down?
Best Regards.
Best Regards.
quick down? quick down-shift?
I'm confused now
I thought these were the only steps, but we also have to press the quick down shift and quick down?
Thanks!~~ ^^
Thanks!~~ ^^
mangap (07-03-2020)
Originally Posted by necrotix
I'm confused now
Thanks!~~ ^^
Thanks!~~ ^^
Nothing to be confused about, just push down the accelerator as far down as you can.
2006 C230 2.5 V6
I just performed the throttle reset and WOW!, did it ever wake up this car and so simple too. I wonder if the adaptive feature will require a reset periodically. Thanks for tip!
2006 C230 2.5 V6
Originally Posted by SeanSBA
after doing this, will you gas mileage decrease since it isn't used to your driving style anymore? just wondering.
Received 1,725 Likes
2016 E350 Sport
ECU Reset... Has anyone tried this procedure?
For those with automatic trannies, check out this thread on resetting the adaptive transmission and throttle settings...
https://mbworld.org/forums/w211-amg/148019-holy-crap-you-guys-sneaky-ecu-reset-works.html
I'm wondering if anyone has tried this on their W203? It should also work on our rides...
