DIY: Front and Rear Sway Bars
Old 11-24-2006, 01:33 PM
rlee02135's Avatar
2004 C32 ///AMG
This is a DIY to replace your stock sway bars.
I replaced mines with H&R.
FRONT
1) Place Front of Car on Rhino-Ramps
2) Remove Bottom Pan (Six 8mm Screws)
3) Remove 16mm Nut on both endlinks (hold 8mm center)
4) Remove two E12 inverted torx bolts on each side
5) Take out Swaybar
6) Put Swaybar in the endlinks, do not put nuts back on yet
7) Put the 2 E12 Inverted Torx bolts back in on each side
8) Put endlink nuts back on
REAR
1) Put Rear Of Car On Rhino-Ramps
2) Remove 16mm endlink nuts on both sides while holding the inverted torx bolt on other side with a 12mm wrench
3) Remove 2 E12 Inverted Torx bolts on each side
4) Take car off Rhino-Ramps, jack up Right-Rear Side and Remove wheel.
5) Pull Swaybar out through that side. (it will take a little while, but dont give up.)
8) Put the 2 16mm endlink nuts back in while holding the inverted torx bolt with a 12mm wrench
The following 2 users liked this post by rlee02135:
ammoun (11-09-2021), DappaDan (06-16-2017)
Old 11-24-2006, 02:25 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Rlee,
great work man. This is exactly what this board needs. More DIY and less wings and stickers.
Did you get any squeeking? Can you comment on how the car feels. Less, Understeer, etc. I'm considering this mod, but a previous poster left zero useful information on the car's characteristics post install.
Again, great job, best post I have seen in some time.
E
Old 11-24-2006, 02:52 PM
14cue's Avatar
05 C55
^yeah what he said
Old 11-24-2006, 04:01 PM
rlee02135's Avatar
2004 C32 ///AMG
there was a lot less understeer.
the car turned a lot sitffer, less bodyroll.
Old 11-24-2006, 06:40 PM
advans's Avatar
C55 ///AMG, 535xi
great job! i bookmarked this page! sways are on my list of upcoming mods!
Old 11-24-2006, 10:17 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
A very well done DIY...
If one is seeking improved handling feel, (and increased cornering speed) upgraded anti-roll bars are a cost-effective and relatively simple modification. After wheels, tires, dampers and springs, they are 'bout all we have left to fiddle with! ...H&R produces quality products. YMMV
Old 11-26-2006, 10:16 AM
rlee02135's Avatar
2004 C32 ///AMG
thanks!
there are a couple different brands you could go with:
Stock: 20 mm front and 13 mm rear
C32: 22 mm front and 16 mm rear
H&R: 26 mm front and 19 mm rear
Evosport: 24 mm front and 19 mm rear
Eibach: 24 mm front and 22 mm rear
i would recommend going with a H&R front and a Eibach rear
Old 11-26-2006, 02:43 PM
white_w203's Avatar
is SOLD
great thread! i guess you leaving your mark here on the forum before you leave the mb family....
Old 11-26-2006, 03:57 PM
rlee02135's Avatar
2004 C32 ///AMG
yeah, i have a few other DIYs planned too
Old 11-26-2006, 04:22 PM
Zillarpillow23's Avatar
What was your final costs including s&h? Great job btw. I'm seriously considering this.
Old 11-26-2006, 04:58 PM
rlee02135's Avatar
2004 C32 ///AMG
around $400
Old 11-26-2006, 05:02 PM
That's very affordable. Are they both H&R?
Old 11-26-2006, 05:09 PM
rlee02135's Avatar
2004 C32 ///AMG
yes
Old 11-26-2006, 06:25 PM
linkmustang's Avatar
where did u buy them at
Old 11-26-2006, 07:18 PM
rlee02135's Avatar
2004 C32 ///AMG
evosport
Old 12-31-2006, 09:06 PM
Super Moderator
splinter's Avatar
If your W203 would like a pair of gratis C32 bars, kindly send a PM. Otherwise, they'll get tossed in the recycle bin!
Thanks to those of you on this forum whose posts inform and enlighten...
Old 12-31-2006, 11:58 PM
wizkid's Avatar
Ford Pinto
Nice writeup. Do you have a problem if I post this on my site www.installuniversity.com?
Did you upgrade the bushings???
Old 01-01-2007, 01:10 AM
rlee02135's Avatar
2004 C32 ///AMG
not a problem...
i used the urethane/Teflon bushings that H&R supplied
Old 01-01-2007, 12:51 PM
RES
RES's Avatar
2005 C55, 1988 260E, 2000 Chevrolet Silverado
I'm not sure on this car but some of the others I've done I removed 1 of the rear tires, and the bar came out easier. I like the bar compairison, I'm looking at changing mine soon but I need struts too so I'm trying to decide on AMG or Bilstien struts. Thanks for the info.
Old 01-01-2007, 12:52 PM
wizkid's Avatar
Ford Pinto
I got the documents up. Thanks, you are doing a great service to the community.
BTW, you mispelled "Parting" out sale in your sig.
Old 01-01-2007, 04:06 PM
PM sent.
Old 01-01-2007, 05:59 PM
Super Moderator
splinter's Avatar
">..PM(s) sent..."
PMs replied. Thanks for your interest.
Happy modding and many pleasant MB miles in '07!
Old 11-07-2007, 02:48 AM
Moderator Alumni
TruTaing's Avatar
w203 m112
Does anyone know if sedan/wagon and amg/non amg/4matic rear sway bars are interchangeable?
Thanks!
Old 11-07-2007, 08:37 AM
MidnghtPressor's Avatar
05 C230K SS
i have been reading, and i have heard that the sport models have amg sway bars. am i correct?
Old 11-12-2007, 12:28 PM
05 C230K SS
ANYONE?
Quick Reply: DIY: Front and Rear Sway Bars
