Ughhhh!!! W203 koni struts vs me
Old 07-06-2013, 01:36 AM
05benzos/c's Avatar
W203 C230K MK4 1.8T GTi
OK so i bout the Koni yellows for my wife's car and guess what... The end links don't fit!!! the stock ones are too tall and its the 12MM so it the hole is too small on the strut... what can I do? The car has been sitting for a while now and thats the last thing i need to put.
Old 07-06-2013, 07:34 PM
fleishman's Avatar
2002 C32 AMG
Search a few posts about drilling out hole on the strut to fit upgraded 12mm bolt. What do you mean by end links?
Old 07-06-2013, 10:55 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
Their mounting hole must be enlarged to accommodate the 12mm links:
Old 07-07-2013, 03:37 PM
05benzos/c's Avatar
the endlinks are too short and the hole is too tall can I use sway bars.with the 10mm holes instead? or who makes aftermarket sway bar ens links
Old 07-07-2013, 04:39 PM
Super Moderator
samaritrey's Avatar
THE C350
I have not heard of an issue with the end links being to tall if I am not mistaken the 10mm ones are the same length. Hopefully it all works out for you I am waiting for a rear set of Koni shocks for my car sadly there is a two month wait so I have another month to go.
Old 07-07-2013, 05:06 PM
05benzos/c's Avatar
This is for the fronts ill take another picture
Old 07-07-2013, 07:31 PM
Super Moderator
samaritrey's Avatar
THE C350
Oh I know you are talking about the front. A picture would help but are you sure the end links are not just siting strange because the car is not on the ground?
Old 07-07-2013, 11:16 PM
05benzos/c's Avatar
yes when I pull the sway bar up to get closer its still like a inch away
Old 07-08-2013, 12:25 PM
hcoronado's Avatar
2021 GLC300 4Matic
I went through the same process when I upgraded the end links from my 2003 to a 2005.
1-Get yourself a good drill bit and mount everything.
2-start enlarging the mounting hole.
3-mount end links and you are done. "you will have to push up the lower arm with the help of a jack to get the end link in position". You want to stay with the end links you have (sport). If you switch to the non-sport ones which are 10mm will be a downgrade.
Old 07-08-2013, 02:24 PM
TTR
TTR's Avatar
R129 SL500 & W140 S500
Good thing I read this post, I was about to order some Koni Yellows for my '01. I thought Tire Rack was pretty good with ensuring that things fit without modification because I was going to get the ones suggested by them. On their site they suggest: 8741-1412SPORT for the front and 26-1679SPORT for the back. Are these the ones that you ordered? I'm curious if anyone has done this upgrade and it was just a quick bolt on and done, no modifications required.
Old 07-08-2013, 03:29 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
I had them done on my 2002, and didn't pay for anything extra when they were installed. IIRC, early W203s did not have this problem at all (and I did order them from Tirerack, btw, as they were the best prices).
Old 05-03-2016, 07:08 PM
Vlad270's Avatar
CLK W209 270 CDI
Hi there. I have the same problem at my W209 CLK 270CDI. How did you solved the problem in the end?
Attached Thumbnails Ughhhh!!! W203 koni struts vs me-20160430_162503.jpg   Ughhhh!!! W203 koni struts vs me-20160430_173509.jpg
Quick Reply: Ughhhh!!! W203 koni struts vs me
