How to remove decorative outer threshold ?
Sorry, could you be a bit more descriptive, or put up a pic? My guess is that you're talking about the door sill, but not sure.
Hello again.
I want to replace this threshold:
https://www.dropbox.com/s/04qyrw32ocupd3q/IMG_1164.JPG
https://www.dropbox.com/s/tetlih6jsq...3_Facelift.jpg
Outside decorative plastic threshold. I pull all clips, but no remove it.
Sorry for my bad english.
No problem on the English. The pics will help; unfortunately, I've never removed that piece. Hopefully, someone will have done this before and post an answer for you.
Did you jack it up and look at the inside of it? Just wondering if there's an inner lip that you have to push it out from under or another inside trim piece that helps keep it where it is.
You mean under this decorative plastic threshold there are clips:
https://mbworld.org/forums/attachmen...-door-sill.jpg
How to remove this decorative sills ?
Yep, that's what he means. The door sills you just basically pull off from the body, except there's one in front that you have to worry a bit about. Be careful! The door sill panel clips are very delicate.
