2002 c230 kompressor coupe
Old 04-20-2015, 03:24 PM
2002c230coupe's Avatar
c230 2002 coupe
I am needing to replace the MAF. I have once before removed the maf, sprayed it down with the MAF cleaner, replaced back in the engine, cleared the Check engine light and drove for thousands of miles without issue.
But now, the CHeck engine light is back again. I tried doing the above, but the light came back on the next day. I think I should probably just replace the MAF altogether. I found a relatively cheap BREMI MAF from fcp euro:
https://www.fcpeuro.com/products/mer...sor-1110940148
I know the MAFs on ebay are bs, unless they were the OE Bosch, but in this case, do you think BREMI might work? Anyone's done this? They say they will take returns if it does not work out.
thanks
Old 04-21-2015, 01:46 PM
Former Vendor of MBWorld
FCPEuro's Avatar
Mercedes
The Bremi units are fantastic quality as Bremi is an OEM to other makes for certain products. VDO was the OEM for this particular part. We will absolutely accept the product back if you run in to an issue with it or are unsatisfied for any reason.
--Kyle
Old 05-08-2015, 04:50 PM
c230 2002 coupe
I ended up buying the bremi maf and it seems to work so far. I will report back after a few hundred miles worth of driving. But I am happy i came across fcp euro, looks like i finally found a competitively priced source for mercedes parts. Not to mention the free shipping and returns. I might be getting the transmission oil replacement kit and a few rotors soon!
Old 01-27-2016, 04:03 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Is it still working well? I'm getting P0171 (too lean) error and this is one possible problem.
Old 01-28-2016, 12:00 AM
c230 2002 coupe
yes still going strong. Forgot i ever had this problem, a really painless purchase\install. I think more than a few thousand miles in with this maf.
Old 01-29-2016, 04:06 PM
DACHIGGA's Avatar
2002 CL203
I'd check the o2 sensor first. Or should I say replace. They are dirt cheap anyways.
Old 01-29-2016, 07:33 PM
Done. I had put a new one in a while back, but these knuckleheads at a muffler shop damaged it, and I put the original one back in.
Now I've just installed a new one.
So we'll see!
Old 03-01-2018, 06:03 PM
KeeganC230k's Avatar
2002 c230K Coupe
So we'll see!
Did the o2 sensor fix it? I've been dealing with the same code and cleaning/replacing the MAF did not help. I have a 2002 c230k coupe as well. Thanks.
EDIT: I managed to find your post on another thread about changing to a bremi MAF. Im trying to find out what MAF sensor I ordered to replace mine.. only paid 40 for mine...maybe not high enough quality?
Old 03-01-2018, 09:06 PM
Probably not.
Check all the hoses etc.
I had a few hoses that were shot coming off the piece that sits on top of the supercharger on 2002.
Also if your 02 sensors are old, replace them. They are supposed to be replaced every 100K miles.
Also, you might have a leaking intake manifold.
I never have but the R170 forum on benzworld seems to see it frequently, the real experts on the M111 engine.
I'm on my 2nd Bremi MAF and FCP Euro doesn't even carry them anymore, got mine from
RM Euro. The 1st one, the guts got blown out the side, Coulda just glued it, maybe, but it was under warranty, so
I got it replaced for free. Perhaps being a forced induction, maybe it wasn't designed to handle the pressure, but that being said
it passed smog and it's 100 bucks not 300.
KeeganC230k (03-01-2018)
Old 03-01-2018, 09:42 PM
Old 03-01-2018, 11:37 PM
2002 c230K Coupe
Probably not.
I found out what MAF sensor I bought: https://www.ebay.com/itm/MASS-AIR-FL...25.m3641.l6368
I was wondering if this is the bremi one you replaced yours with : https://www.gorezsale.top/sensors-c-...30-p-9201.html
As for the O2 sensors I will have to see about getting that diagnostic tool! Seems handy. I have not even gotten halfway to 100k miles yet on my 2002 so I am not sure if the o2 sensors would need replaced yet. This code just seems like such a wide range of possibilities!
Hoping Its the MAF still... I may have to have someone test my hoses for leaks...
Thanks for your replies!
Old 03-02-2018, 05:41 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
I put a bosch MAF a few years ago and still works with no issues. Sure beats paying 400+ for a genuine mercedes one which I am almost certain is a bosch part anyways since bosch makes the MAF and Throttle body, mercedes just charges double for the same part. It threw a p0171 code but it was my own mistake.. I was sea foaming the engine and i accidentally got some sea foam on the maf while spraying the throttle which ruined it.
Old 03-04-2018, 10:37 PM
Yeah, just bought a Bosch recirculating air valve throttle body, 350 vs. 1500 from Mercedes.
Same part.
Old 03-13-2018, 09:09 PM
2002 c230K Coupe
So I cleared the CEL 600 miles ago without fixing anything and it hasn't come back... Odd but I guess ill use my scanner again soon...
Old 03-13-2018, 10:58 PM
$22 MAF?!!! Bwaaa Haaaa! Seriously?
And then that other site,
www.gorezsale.top, they are located ...uh where?
https://whois.icann.org/en/lookup?name=gorezsale.top
Oh yeah, China.
Showing results for: gorezsale.top
Original Query: gorezsale.top
Contact Information
Registrant Contact
Name: ChenChu GuangOrganization: 陈楚光Mailing Address: tianhequjianzhonglu66, Guangzhou Guangdong 510000 CNPhone: +86.01081234655Ext:Fax: +86.01081234655Fax Ext:Email:xtwulf19882@163.com
44 bucks for a nice counterfeit.
Like i said, RM european.Under 100K miles, not likely the 02 sensors.
Quick Reply: 2002 c230 kompressor coupe
