DIY - setting up the AUX input for iPod, mp3 player, etc.
Rating: Thread Rating: 23 votes, 4.65 average.
Old 05-26-2009, 08:20 AM
  #576
MBworld Guru
FrankW's Avatar
white and whiter
Originally Posted by xxhanxx
hey guys after reading the loong thread... i cant find any info on how the wire goes into the center console... as for now... i have taken out the rear ash tray and my fitter the cables through the ash tray area.... this makes it hard for me to close/open the ash tray... is there another way of wiring it through the console? i was reading and some say u can go through the vent on the side of the center console? i tried but am not sure how to. can someone post a pic or guide me here?
oh by the way... my AUX is working
for 2005+ there is no real good way of hiding the wire if you pulled it out from the middle.
Old 05-26-2009, 08:57 AM
  #577
ram_rtg's Avatar
C200K Jul 2004
Originally Posted by Dr.Fox
I'm not the best with electronics, so I'm not sure what D2B means
Is the harness for the 2005+ compatible with the 2002 W203?
I'm no expert either but I think D2B refers to fiber optics system.
I've been looking for a solution to play mp3 on my preupgrade C200K and the best I've found to date is a chinese portable GPS unit that plays everything, transmits to FM and sits in the front ashtray compartment beneath the CD player. I like the look of the stock Becker AUDIO10CD with the steering wheel controls and do not want to replace it.
Upgrading to MOST or COMMAND systems is extremely expensive I think.
Old 05-26-2009, 02:52 PM
  #578
Dr.Fox's Avatar
2013 C300 4Matic Sport
Not only expensive, kind of a pain in the ***. I'm just looking to see if the 05+ unit is plug and play in a 2002.
Old 05-26-2009, 05:01 PM
  #579
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
The 05+ units should be a MOST fiber ring, not D2B fiber, therefore...no, not interchangable. 05+ DVD based navigation and MOST. 04- D2B and CD based navigation.
Old 05-26-2009, 05:15 PM
  #580
Dr.Fox's Avatar
Ah, I see. I'm thinking of the Dension Ice>Link option you mentioned in the other thread...
Old 06-03-2009, 01:55 AM
  #581
speeddemonTsi's Avatar
'05 MB C230Kompressor
Thank you for the op and those contributed to this thread, i went to the dealer today, bought the cable and installed! Very easy install, and i was searching like crazy for 'kits' that were hundreds to have an ipod/auxiliary connection in my car. Im glad i saw this.
BTW, the part number has changed to (A 210 440 50 05). I gave the dealer the number posted in the original post and they cross referenced it and got it anyways. Thanks again!!!
Old 06-30-2009, 04:06 PM
  #582
Emin's Avatar
2010 C300, 2012 Mustang
I have an 06 c230 SS without navi
I have the regular stereo with 6 disc changer
Is my car prewired for this?
Thanks!
Old 06-30-2009, 04:08 PM
  #583
Dr.Fox's Avatar
yes, should be - just remove the panel pictured in the writeup to check for the loose white connector
Old 06-30-2009, 04:11 PM
  #584
Emin's Avatar
Alright, Thanks
Old 06-30-2009, 04:40 PM
  #585
W203E35's Avatar
2006 C350 Sport 6MT
06 should. I heard some 07s don't have them.
Old 06-30-2009, 06:01 PM
  #586
Airplane Guy's Avatar
All of them
Just did mine today.... works great, I paid $30.30+tax with my MBCA discount...
Old 07-11-2009, 09:45 PM
  #587
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
In case anyone is still wondering on installing this, here's my install tips:
I purchased 210 440 50 05 at my dealer for $37 + tax.
The white plug was right where it was supposed to be, attached to a couple other plugs.
The door sill pulls up with clips.
The door rubber pulls up.
The kick panel has a screw in the middle and has a couple of yellow clips that hold it to the metal frame - I pried the clips from the frame, not from the plastic panel.
I did not need to remove the glove box side panel because I was not going to mount the cable there (useless IMO).
I removed the plastic square inside the bottom center console storage compartment to feed the line through.
I ended up installing a 6ft radio shack 1/8" M/M cable in the same exact style that he center console storage wiring is set up. Drilled a hole through the "removable" triangle found in the top center console pocket. There were only 3 screws I believe to get access under there. Squeezed out the cable down the center console (to the carpet) and pushed it up underneath the passenger center console all the way up to the front dash area. I routed the Aux cable behind the carpet in the footwell, yet the Aux + 3.5mm cable were in an area that would not be able to be tucked under the dash due to the bulkiness of the Aux cable head. Headed back to radio shack to pick up an additional 1ft cable and F/F connector so they would be down farther enough (towards the firewall) where they could be tucked underneath the dash and footwell. Everything can be tucked away and hidden from view.
With my Ipod Nano 4G, and the volume all the way up in the settings menu, EQ off, and volume all the way up on the song, I think it sounds excellent. Just a bit louder than the other sources (until you lower the volume of course). The songs seem to have strong bass too, which the stock sub can seem disappointing at times, so that was a pleasant surprise. Mind you, Ipod EQ was off.
Def nice little upgrade, and my nano now sits just to the right of my hand whie driving.
Old 07-13-2009, 12:49 AM
  #588
quzer's Avatar
2007 C280
I have a '07 C280, I can't find the white plug anywhere, I looked around everywhere under the plastic cover by the door and even removed the glove box. The only plug available was a blue one (that didn't match). Has anyone had luck being able to get this done for the '07 C280?
The guy at the dealership mentioned to me that it might be behind the radio, but I wanted to check if anyone has looked there before I go trying to pull out the radio (which I don't even know how to do lol).
I'm pretty confident that the radio has an AUX in somewhere since when I hold the CD Changer button it says AUX INPUT ACTIVE
Old 07-13-2009, 01:03 AM
  #589
EDC320's Avatar
2015 ML350 4Matic
I had the same issue.
It is not there in the 2007 C280.
There is a posting of how to make your own aux cable and connect it to the pins on the back of the radio.
Old 07-13-2009, 01:08 AM
  #590
quzer's Avatar
2007 C280
Any idea of where I can find that posting, I tried searching but I couldn't find anything.
Old 07-14-2009, 03:00 PM
  #591
pointman's Avatar
a car that can't do the throttle reset.
I have tried everything to run the wire from the aux to the center console area and I can't fit the wire anywhere... even after removing the entire front and rear ashtray assemblies, center console, and cupholder areas. Any tips?
Old 07-14-2009, 04:05 PM
  #592
07 Benz's Avatar
2007 C230 Sport
It only works on the few 07's made in 06... weird, I know
Old 07-31-2009, 10:39 PM
  #593
lamonsas's Avatar
2011 C300
Hey guys, so i ordered my harness cable and it will arrive here on monday, however in my car(06 c230) i tried to do the steps but i have a problem, i wasnt able to take out the kick panel trim. i DID remove the screw in the middle but i just tried pulling, pushing and it doesnt come out, how exactly do i remove it guys please help me out, does it need to be pulled, pushed or what?
Old 08-02-2009, 04:02 AM
  #594
phister's Avatar
06 C230 SS 6spd
Dont pull it... if you actually look at the kick panel there's actually a bolt holding the panel on... you'll either need a star screw or an allen wrench to remove it... I forgot which one it was, I used a star screwdriver I believe, after that you can pull the kick panel off.
Old 08-02-2009, 09:36 AM
  #595
lamonsas's Avatar
2011 C300
i already removed the screw in the middle, for me it was a regular phillips screw
Old 08-03-2009, 10:26 AM
  #596
Pixelz's Avatar
W203
I found it easiest to lift the door edge seal around the kick panel, then pry off the two yellow retaining clips that attach the kick panel to the trailing edge of the door opening. Then the panel come off by raising the bottom edge and rocking up and down until it came off rearwards. But be dead sure you removed the torx bolt behind the small access cover in the centre of the kick panel first!
To be honest this was the toughest part of the job for me, but I was very careful and reluctant to force anything. But taking time here did pay off.
BTW, I also found you need to be careful removing the cap from the stereo jack socket, before you push it through the glovebox hole -- it's easy to break the plastic prongs. But it's worth doing this so you can snap the cap back on from inside the glove box and prevent the socket from getting pushed through the hole when you plug in an ipod.
Hope this helps.
Old 08-03-2009, 07:04 PM
  #597
drbyee's Avatar
c240
Hi all:
I am installing a 6 disc CD Changer in my 02 C240 Elegance. I've found the fiber optic cable but still can't find the power cable. I'd appreciate any insight, tips or ideas of where specifically it might be....
Thanks.
Old 08-06-2009, 10:26 PM
  #598
iozker's Avatar
2007 c230 sport
Exclamation ----------> HELP ! <----------
HEY EVERYONE I LOOKED IN MY CAR BUT I DID NOT FIND ANY WHITE CONNECTOR... ALL I FOUND WAS A BLACK CONNECTOR WITH 2 BLUE WIRES THAT IS NOT CONNECTED TO ANYTHING... IS THIS THE CONNECTOR IN MY CAR? I DRIVE A 2007 C230 SPORT SEDAN
Old 08-07-2009, 01:26 AM
  #599
ctwz's Avatar
08' C63 AMG, 89' BMW 525i
am gonna have the aux jack done tmr by a mechanic, went to al and ed's they quoted me 300 but the mechanic recommended by my dealer is only charging 150. taking into account that im rubbish with DIY technical stuff, is 150 a good or rip off price?
Old 08-07-2009, 08:38 AM
  #600
lamonsas's Avatar
2011 C300
its a rip off dude, the only hard thing is to remove the KICK PANEL, other than that its easy
You have already rated this thread Rating: Thread Rating: 23 votes, 4.65 average.
Quick Reply: DIY - setting up the AUX input for iPod, mp3 player, etc.
