Bluetooth Phonebook Transfer on W204
Old 12-29-2008, 04:20 PM
nyca's Avatar
and the blackberry bold works.
Old 12-29-2008, 10:46 PM
LapazC350's Avatar
2008 Mercedes C350
i tried it with the curve it said i need a object push w/e that means -_-
Old 01-09-2009, 08:43 AM
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
BlackBerry Bold works 100%. Nokia 6300 (S40) cannot send all contacts by BT, go figure one by one Going to export them to laptop and then send them.
Old 02-06-2009, 02:58 AM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Originally Posted by Teck
As far as I know you should get this at the parts department at your MB dealer. MB made this cradle after Iphone released the 3G version because of the bluetooth problem of the Iphone. Paid about $500 for this thing (works fine but IMO not perfect it don't shows sms and you don't have your own ringtone just a crapy MB one....but I had the same prolem with the W203).
Why pay $500 - Its around $300 if you buy it from the site where that picture link is in the post further up.
You need the comfort phone option (which may be part of a package, or standard, on US cars) that gives you the phone connector in the glovebox for the iPhone cradle to plug into.
iPhone cradle also has an audio output that can connect to an iPod kit or Media Interface with the appropriate additional lead.
R
Old 02-10-2009, 07:05 AM
kahoon's Avatar
'06 M Coupe, '06 BMW R1200GS ADV, '06 BMW HP2, '06 KTM 950 ADV, '09 MB C300W MT-6 (arrving July '09)
For those of you that said a Blackberry works, did you simply go to the Bluetooth menu, highlight the car paring, and select "Transfer Contacts" from the pop-up menu?
Thanks in advance!!
Old 02-10-2009, 08:42 AM
seminole_kev's Avatar
'09 C-300 Luxury and 1967 Jaguar mk2 sedan
Just figured I'd add it here in case anyone else experiences it, but with Sprint on a couple of different versions of Motorola razors, I've found that if you (from the phone side) try to transfer contacts as "Send Business Card" it will import, but incorrectly/unusable. If you transfer as "Send this Contact" instead (again, from the phone side), it will send the info correctly.
Old 02-10-2009, 09:16 AM
  #32
TB5...'s Avatar
2009 C300 4Matic
ohhhh that's how you do it... smh i was struggling with this htc touch pro...
might the bus card transfer at lunch.
collective knowledge >
Old 02-10-2009, 01:03 PM
  #33
ctgilles's Avatar
Thanks in advance!!
I "opened" it for BT transfer and then had the BB send all contacts over.
Old 02-10-2009, 01:13 PM
  #34
javavu's Avatar
C350
I couldn't get this to work with my G1 phone, ended up having to use my old BB Curve, and all is well now.
Old 02-10-2009, 02:55 PM
  #35
nguyenmd350slk's Avatar
05-350slk and 08-c350
Originally Posted by Chaz00Blue
I have one of the newest Blackberry's and I was disappointed that I couldn't get the address book over. It seems like this should be something that has a solution by now.
I used blackberry curve 8320 transfer in 1 minutes, 200 names.
R u sure u can't transfer with your blackberry?
Old 03-21-2009, 11:38 PM
  #36
Mrsl500's Avatar
SL
I have the answer yes it can be done, here is a link with the procedure.
http://mercedes-benzbluetooth.blogsp...comand-or.html
It can be done via the phone business card process, or via the Mercedes Benz SAP phone cradle form the sim card directly.
hope this helps!
Here are some more helpfull links.
http://mercedes-benzbluetooth.blogsp...2009/03/1.html
http://mercedes-benzbluetooth.blogsp...y-pairing.html
http://mercedes-benzbluetooth.blogsp...h-pairing.html
Blackberrys are different, you cant download the phone book, but you can off the sim card with the new Comand system.
Old 03-21-2009, 11:48 PM
  #37
Mrsl500's Avatar
SL
http://mercedes-benzbluetooth.blogsp...ap-cradle.html
another helpful link
Old 09-06-2009, 09:24 PM
  #38
jmartinacevedo's Avatar
2009 C300 SPORT 4MATIC
HOW I DID IT
1. Paired my bluetooth laptop (131) with the car;
2. Imported business cards (.vcf) from Outlook into bluetooth exchange folder;
3. Set the car in business card "receive" mode;
4. Pushed the business card(s) to the car via bluetooth;
5. Car received each card and stored it in the address book.
Yes, you have to do it one by one but each transfer takes only a second so overall it's fast.
(Pics are not in order but you get the idea.)
Old 09-07-2009, 10:25 AM
  #39
orie's Avatar
2008 C350 Sport
I have a BB Storm and the non-multimedia system in my 350. I've had issues transferring my numbers over. Can't figure it out.
Old 09-07-2009, 10:42 AM
  #40
Doanster's Avatar
C300 Sport 6MT
Assume you've already gotten the Storm paired up to your car.?
Then go into the Tel menu and then select Receive Business Cards. The screen should show "Ready to recieve" w/ a count of zero.
On your Storm, go into BT settings, scroll down to MB Bluetooth and hit the Menu button. You should have a Transfer Address Book option. Hit that and the car should receive all your contacts. Very quickly, I might add.
This worked for my Pearl yesterday w/ my non-MM system...
Quick Reply: Bluetooth Phonebook Transfer on W204
