Old 06-10-2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
DIY oil change, step by step, with pictures
Rating: Thread Rating: 11 votes, 4.27 average.
Old 02-03-2014, 03:25 PM
  #451
dave2001auto's Avatar
84 300d 2009 e320 bluetec
Originally Posted by Pete7874
Sorry, you lost me there. But in general, yes, all MB approved oils will be on the thicker side as they require to have HT/HS of at least 3.5 cP.
Also, 15w-45? Never heard of such a thing.
typo 15W-40 not 45 as originally typed.
For most good oil, better will be engine dependent and emission control dependent. Best for one car may ruin another car.
In a nut shell, use the approved oil that includes brand, formulation and weight, not just approved brand and weight.
See
http://bevo.mercedes-benz.com/bevoli...ets-sort1.html
and to see which ones are MB approved.
Beware mfg do change their formulation. Look on the bottle to see if they still met the MB specifications.
Old 02-03-2014, 08:23 PM
  #452
Pete7874's Avatar
'08 C300 4Matic Sport, '02 530i
Yup. That's why I wrote...
focus more on the mfg performance specs that an oil meets rather than on what group its made of.
What I meant by it was to use 229.5 approved oil if you have a gasoline engine and 229.51 approved oil if you have a diesel engine.
Old 03-28-2014, 10:15 PM
  #453
loudbimmer's Avatar
2001 BMW 325i, 2011 Mercedes C300 sport
quick question, on 2011 c300, how many quarts of oil does it take?
I went to advanced auto parts, and their computer showed that it needs 7.2 quarts, but this guide is saying that it needs 8.5.
Old 03-29-2014, 01:54 AM
  #454
Your owner manual should list the oil capacity (how much) and viscosity needed.
Old 03-29-2014, 12:51 PM
  #455
Pete7874's Avatar
RWD cars take around 8.5 qt. 4Matics take about 7.5 qt.
Old 03-31-2014, 02:50 PM
  #456
milltek's Avatar
1999 ML430 2009 C300 4Matic Lux
Hi,
Just wanted to add some information about my recent oil change. First, this thread is really a great help when you go to change the pile for the first time.
Anyway, using a MightyVac MV7400 I was only able to get around 4 - 4.5 liters out before it started sucking air. No matter how hard I pumped it just kept sucking air.
I re-examined this thread and saw that several people had made adaptors to seal the top of the oil dipstick tube to the MightVac plastic pipe. I ended up taking about three inches of Duct Tape and wrapping around the top of the dipstick tube and squeezing it tight to the thinner MightyVac tube.
A couple of quick pumps on the handle and all the rest of the oil came out. Worked a treat!!!
Old 03-31-2014, 03:23 PM
  #457
Originally Posted by milltek
Hi,
How much more did you get out?
Try a 10 mm or 3/8" tanny/oil hose. It should fit snuggly into the dip stick tube and some silicone tape. The newer MBZ is designed with the DS tube all the way to the bottom of the oil pan, so a larger vacumn tube can be used to make the job faster.
Old 03-31-2014, 04:27 PM
  #458
milltek's Avatar
I got another 3 - 4 liters out. Sorry about the somewhat vague numbers but I did not mark where the initial extraction stopped so I'm guessing a little.
Old 03-31-2014, 04:46 PM
  #459
Critter's Avatar
07 E63 + 07 CLK63CAB
Personally I like to drain mine under the car into a radiator tub with spout, when all the oil is finished dripping out then I replace the crush washer on the plug and tighten, then go to the cooler at the front of the car and drain out the rest from the drain, replace crush washer and tighten. Replace the filter while everything is draining and then pour 9.5 liter into the engine. Using the rad tub I pour the old oil into the used jugs that were just emptied and this gives me an idea of how much oil the car is burning. No guess work, simple. So far minimal oil consumption maybe 1/2 liter @ 5K mile oil change intervals, usually less than that.
Old 03-31-2014, 05:44 PM
  #460
Cillys's Avatar
2011 C300 Sport 4MATIC
I bought this on Amazon. Even comes with an adapter that fits the dipstick tube with a rubber seal. Plus works great for other cars too utilizing their dipstick tube. Comes with various other adapters and tubes.
Amazon.com: John Dow Industries JDI-6EV 6 Gallon Fluid Evacuator: Automotive Amazon.com: John Dow Industries JDI-6EV 6 Gallon Fluid Evacuator: Automotive
Old 03-31-2014, 06:34 PM
  #461
Cillys. Amazing price over half off. A profession grade tool for under $250 What type of suction hose is used? Any reinforcing to prevent tube collapse from vacuuming the hot oil? Looks like it's fast with the large hose.
Old 03-31-2014, 06:40 PM
  #462
Cillys's Avatar
Actually you hook it up to an air compressor and it creates a vacuum in the tank and then you open the valve and it sucks the oil from the dipstick tube. It discharges under low pressure. The hoses don't fail under the hot oil. It's very similar to Fluid Evacuators that purportedly the MB dealers use.
Old 03-31-2014, 09:31 PM
  #463
nyca's Avatar
So you have to run your compressor to charge it, then use it to evacuate? Too much work, my marine unit that runs on 12V power is a one piece, compact unit that does it all - runs a pump off your battery, sucks the oil into a container using a diptube adapater shown elsewhere on this thread. So far, for what it costs, I have yet to see a setup that beat that for the occasional DIY user. IMHO of course.
Old 04-01-2014, 05:55 PM
  #464
Lots of equipment in a garage is run off compressed air. The vacuum in the tank is created by air driven aspiration pump (a lot cheaper than a tradiational vacuum pump). After a few oil drains, the compressor is used to pressurize the tank and force the used oil out into a larger holding tank or drums. It's a really nice set up for large volume usage. It's not yet at my price point for a purchase.
Old 04-01-2014, 09:19 PM
  #465
nyca's Avatar
I do 3 changes a year, which is more than the norm. But many people just do one change a year, so a compressor PLUS an evacuation unit is alot of gear for a DIYer for someone who does one change a year.
Old 05-12-2014, 08:10 PM
  #466
timham40's Avatar
C250
Mann VS OEM Oil Filter
I bought The Man filter HU 514 X and the O-Rings were not correct. I had to stop what I was doing and head out to the MB dealer and bought the OEM version. This had the correct rubber O-Rings.
IF you care to see in the picture the Mann O-Rings are thicker the smallest of the 3 broke when I tried to put it on the
Any thoughts?
Attached Thumbnails DIY oil change, step by step, with pictures-20140512_193044a.jpg   DIY oil change, step by step, with pictures-20140512_193134_1.jpg
Old 05-12-2014, 09:45 PM
  #467
nyca's Avatar
That's not the oil filter for the C250 - use the auto parts finder on amazon.com, it says that isn't the one.
Old 05-13-2014, 01:32 AM
  #468
C0d3Sp4c3's Avatar
2013 C250
Any thoughts?
Ouch... for C250 it should be Mann HU514y and not HU514x
Old 06-11-2014, 12:14 PM
  #469
GMTK's Avatar
2010 C300 Luxury
Great read (took 2 hours). Thanks to all who contributed.
Two questions:
1. What is the proper torque for the drain plug?
2. What oil is recommended for South Texas during the summer?
I understand the suck vs. drain oil argument and don't want to re-hash it.
Also, I will change the oil again this fall, but want to make sure I have the proper oil for the summer, in Texas... (highs of 110 degrees...)
Old 06-11-2014, 01:33 PM
  #470
Pete7874's Avatar
You can use something like M1 0w-40, regardless if you're in South Texas or Alaska, regardless if it's Summer or Winter.
Using different oils for summer/winter made sense some 30+ years ago. Nowadays, with the availability of high quality multigrade oils, there is no need.
Old 11-10-2014, 10:19 AM
  #471
harryh38's Avatar
c280 2008
suction oil change
A cheap hand pump from e-bay,and old container, takes about 30 minutes to change the oil and filter on my C280 2008
The tolal cost for best 10-50 oil and filter £73 + pump £8
An easy and clean way to do an 8lt oil change via the dip stick access
Any body know why the EML comes on now and again if I delay the oil change but after the change it does not show? the oils not low and the car runs perfect.
Old 12-01-2014, 05:58 PM
  #472
DJ BIS's Avatar
2009 Manual C300 Sport
Some of the 4matic guys mentioned that the manual trans C300 was different when it came to sucking out the oil with a MityVac. In my experience I dealt with the same issue on a 2009 Manual RWD C300. I believe I was only able to draw about 7+ quarts by inserting the "straw" inside the stick and pushing/wiggling it in as much as I could.
So, no different than the 4matic engines. The straw still hits bottom or gets caught somewhere keeping it from extracting all the oil.
Need to read more so I can find an "over the tube" adaptor...
Old 12-01-2014, 06:48 PM
  #473
DJ BIS's Avatar
Originally Posted by snowmuch
How did you guys remove the oil filter? I tried using hands but it was too tight.
THis is a perfect fit on a 2009 C300
Amazon.com: Wr 74Mm Oil Filt End Cp 14Pt: Home Improvement Amazon.com: Wr 74Mm Oil Filt End Cp 14Pt: Home Improvement
Old 03-28-2017, 10:25 PM
  #474
superangrypenguin's Avatar
A car
This link is dead
http://www.fluidevacuators.com/mercedes.html
Where can we buy an adapter?
Old 03-29-2017, 02:59 AM
  #475
Demvang's Avatar
2011 C300 4Matic Sport
Here it is
http://www.fluidevacuators.com/produ...adapter-detail
Save yourself some $$$, use the rubber telescoping hose connector that comes with your fluid extractor. One end for hose, the other smaller end for dipstick tube.
You have already rated this thread Rating: Thread Rating: 11 votes, 4.27 average.
Quick Reply: DIY oil change, step by step, with pictures
