C250, More boosting than you think
2004 Mazda6, 1993 RX7
I've had several cars with turbo's over the years, some heavily modified cars. At one point, I had about 4-5 turbochargers on my workbench.
While at the dealer, I took a good look at the C250 engine. I first noticed that the 1.8L engine had a well fitted, front mounted Intercooler (IC), that would efficiently cool the very hot boosted air (~270F) from the turbo. Usually the IC is smaller and stuffed in the engine bay, where cooling air must be ducted to it. A common mod for these lesser cars is to upgrade to a FMIC, like the C250 has, as built.
But the "magic" shared by most turbocharged cars shows up on the highway. At 60mph a small push on the gas pedal and the car shoots forward like it's got a V8 ... no downshift needed.
This is because while cruising, the exhaust flow is high enough for the turbo to create boost, from the compressor wheel to the Throttle Body (TB). That boost level is controlled to only 5-7 psi, but that is enough to keep the turbo spinning smartly, like at ~50,000 rpms.
For testing purposes, assume you had a pressure gauge reading the intake pipe before the TB, and another gauge reading the intake manifold (that has passage ways down to the back of the intake valves). In reality, the C250 does not have a boost gauge.
So while crusing, you see you have about 5 psi between the turbo and the TB, and 18" of vacuum in the intake manifold (just like in a non-tubo car), but unlike a non-turbo, you have the gas pedal pushed just slightly. Technically, with 5 psi on the back of the TB, to get the same air (and gas) flow needed for cruising on the highway, you need less opening of the TB with the turbo, vs a non-turbo'd car.
Then you want to pass someone, also cruising on the highway. Push the pedal down a bit and you have an instant 5 psi in the manifold for much more engine torque/hp, and the pre-spooled turbo makes even more power/boost almost instantly. It pulls hard because of the very high torque rating at the lower "cruising" rpms.
Simply put, on the highway it acts like you have a V8 under the hood. Now getting rolling from a stop is whole other game ...
HaitianG (01-18-2023)
2010 E350
Coming from the Audi world I totally agree that MB made a great decision in the FMIC instead of SMIC. Definitely huge in reducing heat soak. I wondering when someone will take the plunge and install a disco potato or 30R on one of these c250's and actually make some real power with it?
I just drove around the new c250 for a week and half as my loaner. I'm coming from a 08 C350 and on the highway this car was a beast. BUT, that lag, I have no idea if it's from the turbo lag or if it's just a transmission issue, or even the electronic drive by wire accel pedal, I can't live with. I thought my car when I first got it had horrible lag when I stepped on the gas (my previous car was a 05 Civic Si which I have boosted, took turbo out went with stage 3 NA cams, was working on a crv block and rex type s head with forged internals with Jackson racing supercharger mounted) But I think the C250's initial lag is dangerous as well as annoying, I think I've had couple times where I'm trying to make a left turn and I think I have enough time to avoid the car coming towards me, and when I try to go I'm sitting there for extra seconds and realize that I can't make it anymore. But you are right, on highway it's a beast and a fun car to drive.
2024 GLS450
E definitely exacerbates the lag over S, but for just puttering around I don't mind. I've actually found that it makes me a more relaxed driver. On my average commute, my tach rarely goes over 2,500 RPM so I'm not really hitting much boost though. The main place where I look for power is from about 30-70 MPH for merging, which it has no problem laying down.
I came from a smart - it's got some similar characteristics off of the line due to the speed it engages the clutch, so it wasn't a huge adjustment for me. It definitely teaches you a different driving style - that's for sure.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
2024 GLS450
It's probably just a muscle memory issue for me honestly, and if I ended up buying a c250, couple weeks and I'll adjust to it accordingly since my reaction coming from drive by cable to drive by wire was the same reaction. C250 is a blast to drive no doubt, and I love the mod potential of factory turbo cars. And yes I did drive on E. What do you get MPG on your 250? Seemed like it gets amazing MPG!
You could be lugging the engine, shifting that low. Lugging includes high crank bearing loads at low speed where the oil film thickness gets little hydrodynamic contribution.
One factor that influences the mpg's is the BSFC (Brake Specific Fuel Consumption) for the engine.
BSFC = (lb/hr)/hp
If you compare the C300 and the C250, with both pushed hard, the C250 would likely burn more fuel, as turbos are set extra rich at high output. A high BSFC of ~.62 for a turbo means more fuel burned per hp, vs a value of ~.47 for a NA engine. Copied info:
So the problem becomes the use of BSFC if we can’t calculate an exact number for an engine. Well, we can get a range of BSFCs for engines. For example, in our last post I used 0.65 as a safe number for a turbocharged engine. Most turbo’d engines run between 0.6 and 0.65 BSFC while supercharged cars have a BSFC between 0.55 and 0.6, and naturally aspirated engines use only 0.45 to 0.5 Lbs/Hp*Hr. These are only approximations, but you can clearly see the difference between naturally aspirated engines and turbocharged engines. Turbocharged engines usually require more fuel to keep detonation at bay due to the increased temperature and pressure of the intake air. This is why a turbocharged engine uses more fuel per horsepower per hour.
math-behind-turbocharging-part-3b-brake-specific-fuel-consumption-bsfc/
2024 GLS450
I tend to accelerate very gently if I am just puttering around, so the engine is almost inaudible, but it does not feel/sound like it is shuddering when you do hear it though.
2012 C250 Coupe
I drive my car like an animal. Have my Stage 1 tune installed up to 100% from JB+ and the intake installed. As well as a free flowing (post-cat) quad exhaust setup. I love it. The car definitely does move great. Although, I think I'm creating too much boost (as there can be too much). I get a sort of "pulsing" of PSI through the engine. And if I don't pull back, will hit overboost.
What is weird is that this doesn't occur on WOT applications, but rather "heavy foot" applications; where the throttle is maybe 60% down. Do you have any idea what could be causing this. You can actually hear and feel a lurching of power where there is more power, less power, more power, etc.
Also, after these mods, there is essential ZERO lag in "S" mode. However, "E" mode is pretty bad lag. Especially when stock. I have also found that E mode gives MUCH greater fuel economy on the highway and around town on the C250, where my previous C300 did not.
I drive my car like an animal. Have my Stage 1 tune installed up to 100% from JB+ and the intake installed. As well as a free flowing (post-cat) quad exhaust setup. ....I get a sort of "pulsing" of PSI through the engine. And if I don't pull back, will hit overboost.
What is weird is that this doesn't occur on WOT applications, but rather "heavy foot" applications; where the throttle is maybe 60% down. Do you have any idea what could be causing this..
Also looks like they tinker with the gas pedal response, aka sprint booster.
JB for C250, + dyno graphs
Putting rims
Any rims u put is gonna degrade the ride quality ur putting more rim less rubber in my opinion my 12' c250 coupe had the sport package and it was firm to begin with so for me it was a no brainer why sacrafice the potential of the look of the car that it gets with 20's which looks absolutely stunning might i add for one inch less leaving it look like its lacking or cheap to me... when with 19's ur still gonna get the ruff ride? Smh if u want the look u sacrafice the ride quality a little bit ..stop crying ohh it rubbs its ruff its to much of a hassle ive had 20's with 35+ offset tires (poking past fenders a little) everyone said 50 48 positive offset was the way to go anything else ull rubb like as if it wouldent work at all or it wasent worth the hassle ..i wouldent give a millimeter of offset back ..it makes the car it creates the look.. ive been driving hard on it on messed up miami streets for almost a year now yea they rub on hard bumps yea i feel every little nook and cranny on the road ...but all i get are compliments and when i got people in my car they never ever complain only grin cause their happy to ride in such a pimped out whip...
Make ur choice
Dont fall for the hype
Im grateful for this site as a resource but i wouldent recommend following anything blindly...
Make ur choice
Make ur choice
Make ur choice
Edit sorry wrong thread
The old thread bump made for an interesting read at least.
Too bad there isn't a real ECU remap for this engine. It could probably get an additional 30-40 hp and eliminate the adaptive throttle lag.
Yea i cant believe 4 years later still no concrete set up to do no diy write ups nothing that anyone has really done to make the car faster relatively safely... thats why i build the mustang... the aftermarket the knowledge the resources are overwhelmingly abundant... when i decided to go turbo i read up on diys one after the other all day for weeks (crane operator lots of down time and phone usage lol) to the point that i just had to find a reason to stop because the information just never ends...
Wat is this vag community i do not speak this languages
....KevenK2's turbo notes made this sailor smile (especially the highway dynamics part)......
The MPG potential - well now I understand.
I bought this little coupe for its' striking good looks. The turbo enriched boost supplements those good looks for this sailor.
Thank you Seņor Kevin..................
ez
ez
