Tail light connector melted
Old 02-05-2014, 09:35 PM
  #176
ptirado's Avatar
2008 C350
Please go to the NHTSA website and enter your complaint with your VIN. They have an open investigation that was started on December 20, 2013.
The more complaints recorded will continue to put pressure on MB
Old 02-08-2014, 09:36 PM
  #177
nyca's Avatar
Originally Posted by oakhillslake
I have been experiencing the same issue with My C300. The tail light is out and I am getting several error msgs. regarding my lights on my dashboard. I took it into Walters Mercedes Benz in Riverside this morning. I was told that the issue is caused by a melted electrical component.
I called Mercedes Benz and they told me they are not aware of this issue and due to the fact that I am out of warranty I will have to pay for the $500 repair.
Needless to say, I am not happy with paying to replace a defected part.
The Mercedes Benz customer service rep told me she will forward the issue to an acct mgr who will call me back within 24 hours.
I will post their response as soon as they get back to me.
What do they do for $500? All new parts cost maybe $70 (bulb plates, connectors, pins) - note that I don't think the dealer fixes the problem, unless updated parts have been issued - you just get the current parts replaced and you still have a ground that is too weak and the heat problem remains. Repairing it just buys you more time, unless they have issued new parts.
Old 03-21-2014, 01:04 PM
  #178
why38why's Avatar
2009 C300 Sport 4matic, 2001 Audi S4, 2013 Subaru BRZ
Same issue on my 2009 C300 67K miles, left side burned up plug. Took it to the dealer today and they replaced both sides for just over $100. They acknowledged there was a common issue, and it was under investigation. The dealer covered $250 of the total repair costs, and I was responsible for the rest at $111(about what the parts would have cost). Took about 45 minutes and I was out the door. Overall happy with the service and solution provided. They did mention they would let me know if a TSB comes out, and at that point I can send my receipt in for a reimbursement from MB.
Old 03-21-2014, 04:00 PM
  #179
shotgun_banjo's Avatar
'13 GLK350 4matic,'09 C300 4matic,'15 GLA250,'07 Honda Odyssey, '18 GLE 43
Wife told me last night that one of my rear lights are dimmer than the other while she was tailing me. After pulling the wire on the right side I found the melted connector. Checked the service history of the car and it was replaced already at around 40k and the car is now at 75k. So I am guessing the wires has not been updated just replaced with the same crap wire as stock. The car is still under warranty (extended) and I want to know what does the updated wires looks like so that after the work is done I can check if they used the right updated wires. Does anyone can confirm if the updated wires are holding up or is it better to add another ground after the fix?
Old 03-21-2014, 08:25 PM
  #180
nyca's Avatar
That's what I believe also - when the dealer fixes this, they just replace the existing parts which means it will re-occur eventually. They don't put a bigger ground wire in. I did a DIY repair and use a larger ground wire - will it hold up long term, who knows, but I can feel the entire assembly is cooler with the better ground.
Old 04-03-2014, 04:09 PM
  #181
Got mine being worked on right now. They are replacing the back housing and the wire harness. Good thing I still have extended warranty on the car. I was told that the pins are bigger gauge than the original one but after they put this in I will try to add another wire just to make sure it won't melt again.
Old 06-06-2014, 11:03 AM
  #182
Philipangoo's Avatar
Tesla 3, E30, CayenneS
Guys thank you everyone for reporting the issues to the NHTSA. I am sure many of you have already seen but there is now an official recall affecting over 250k C-Class vehicles.
http://www.detroitnews.com/article/2...ada-fix-lights
Old 06-06-2014, 11:11 AM
  #183
builthatch's Avatar
C63
first post needs to be updated. this is great!
Old 06-06-2014, 11:41 AM
  #184
boom132's Avatar
10' C300 Sport and 07 Ducati S2R
OMG... IT is about time! I already had one side replaced... I'm getting symptoms on the other side now... I can't wait to have this situation addressed.
Thank you for providing an update... -Jason
Old 06-06-2014, 10:48 PM
  #185
nyca's Avatar
Still have not received a letter from MBUSA about this recall.
Old 06-07-2014, 11:25 AM
  #186
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
Sold my C a while ago but this is great news! Glad they are owning up to the problem.
Old 06-09-2014, 02:57 PM
  #187
nismosr's Avatar
2009 C300 Sport 4Matic
Received my letter this weekend about the recall ..
Old 06-09-2014, 06:18 PM
  #188
ptirado's Avatar
2008 C350
The power of the consumer...
And all the GM recalls! Thanks to those who reported it. Strength in numbers. Got my letter today. Attached is the letter advising of the recall. Actual service letter to come later.
Old 06-09-2014, 07:06 PM
  #189
itcrashed's Avatar
MB w204 C300 Sport, Audi B7 A4 2.0TQ, Porsche Cayman 981
Just got my recall letter as well. About friggin time they came clean with the issue. I had my right rear all replaced under warranty back in 2011 and just last week I started getting the same symptoms on the left rear.
Dredging up the thread from 2010 about the issue several of us had back then!
https://mbworld.org/forums/c-class-w...ml#post4520200
Old 06-17-2014, 04:49 PM
  #190
benzdude's Avatar
2015 C300 4Matic Sport
Talking
uʍop ǝpᴉsdn ǝƃɐɯᴉ
Old 06-18-2014, 09:55 PM
  #191
Blue_Devereaux's Avatar
2009 C300 Sport
Dealer's response to recall question
I contacted my dealer to ask if I should bring my car in. This was the response:
"The preliminary notice we received states to repair any vehicles that currently exhibit a tail lamp malfunction. The recall campaign will launch August/September. At that time we will receive instructions as to what procedure to use.
Thank you for your inquiry,
Denny Caylor
Service Manager
Critz MB."
Old 06-28-2014, 01:51 AM
  #192
cvx5832's Avatar
325Ci, 325Cic, C300
I had a similar experience as most in this thread. I started to notice the dimming a couple years ago and it progressively got worse. Today I realized it was too dim to wait for MB. $13 bucks & 45 minutes later everything is sorted out. I followed the DIY by stosoorok in post #100. Only difference being I used 14 gauge wire and I screwed the lead into the holder plate instead of soldering it.
The Benz is now my wife's car so she's happy with the fix too.
This is the before image, park lights only.
Tah-dah.
Old 06-28-2014, 09:02 AM
  #193
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
CVX, your logbook is amazing. I love it.
Old 06-28-2014, 09:10 AM
  #194
cvx5832's Avatar
325Ci, 325Cic, C300
Thanks!!
Old 11-03-2017, 02:55 AM
  #195
Fisz's Avatar
W204 Avantgarde 2.2CDI 170PS
Quick question - is it possible to solder a new ground wire to the bulb plate, instead of drilling a hole in it?
Can I do it without disconnecting the bulb plate? Because unfortunatelly mine is melted, and now I can't disconnect the connector
Old 11-03-2017, 12:27 PM
  #196
JimMBC300's Avatar
2008 C300
I believe it will be very difficult to either drill or solder the bulb carrier without first removing it. Why not have MB repair it under the recall?
Old 11-03-2017, 06:58 PM
  #197
4maticaddict's Avatar
2009 W204
You definitely can solder to the plate. Just don’t let the material run onto any if the circuits or you may cause a short.
Old 11-06-2017, 01:36 AM
  #198
Fisz's Avatar
Because it's Poland, not Deutschland, USA or Canada. I've never heared of any warranty actions about bulb plates in PL. It's a known problem for them, because I talked with service guy at Mercedes, but you must buy it yourself (+ montage costs).
@4maticaddict - thank you!
Old 11-06-2017, 08:44 AM
  #199
JimMBC300's Avatar
2008 C300
Taillight connector melted
Sorry that Poland doesn't require MB to correct a safety proble like this. Also sorry that MB doesn't take responsibility to correct a safety problem. If the melted connector prevents removal of the bulb plate, it will be difficult to replace a burned out bulb when that eventually happens.
Old 01-24-2018, 06:41 PM
  #200
EricHaleSand's Avatar
2010 C300
Talking Very informative and precise....!
Originally Posted by Big Daddy
Unfortunately these tail light assemblies are not the result of typical German engineering, but are a result of some very poorly thought out electrics.
As all the current from the tail light assembly from each light bulb passes through the brown earth wire, when you have a small resistance in the pin connections ie. one or two ohms and with all lights operational, that is stop, indicator,reverse, tail and side lights the peak current can be near 8-12 amps.
Ohms law gives us heating power of about 20 watts. This is the same as a small soldering iron. Not something you want hidden away in the trunk. if you examine the connector you can see that it is not designed to carry this amount of current or disperse this type of heat.
Mercedes really screwed the pooch when they let this design pass the scrutiny of the QC team. The earth connector should be at least 3 times larger than it is at the moment, or a fixed wire from the main Earth connector on the power module to the bulb holder earth will cure the problem
Posted this on another thread
Hey Big Daddy....This post was right on the money and because of it my MB dealer here in Monterey, California is going to replace all the needed parts, I just hope the ground wire in the new rear wiring harness is at least 10 AVG. I will also be sending my letter explaining the problem and pix of my "burnt out" wire assembly to their "problem dept." located somewhere in our mid-west like Missouri. A "tip o' the hat" to you and thanks again.
Quick Reply: Tail light connector melted
