Tail light connector melted
Old 09-30-2012, 03:41 PM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
Take a look.
This is the connector for my right side tail light. The left side is perfectly fine.
It looks like the brown wire melted right through the plastic. The receiver on the bulb board is toasted too. (This is the wire closest to the OUTSIDE of the car, if you are looking at the connector while it is plugged it in it is the leftmost wire.)
When I removed the brown wire and plugged in the connector nothing worked.
Update: I'll be heading to the dealer for a new bulb board and connector Monday morning. I'll try to work on it when I get home tomorrow night.
EVERYONE SHOULD CHECK THEIR TAIL LIGHT CONNECTORS FOR ANY UNUSUAL SIGNS OF WEAR. They are VERY easily accessible through panels inside the trunk. The bulb board simply clicks off. This seems like a common problem and if caught early enough you can probably avoid having to get another bulb board.
Old 09-30-2012, 04:22 PM
snowmuch's Avatar
C63 AMG
It seems that more and more people are having this issue right now. My dealership just changed my out last week because my melted too.
Old 09-30-2012, 05:09 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Mine started last night. I found info from June 2011 where I went to the dealership for a bulb out message, but couldn't find a burnt bulb. When I came back to me car- 3 employees where at my trunk with a set of needle nose pliers. They said there were issues with the connector coming loose from the harness so they were "checking" them for me. I can't completely remove my harness from the light assembly because I can't get the brown wire loose. If I partially reinsert the harness- my bulbs fully illuminate. I'm at 53,000 miles (3K out of warranty) so let's see what they will do.
Old 09-30-2012, 05:58 PM
E350 Sport/ML350RWD
Do any of our MB gurus have access to determine if the is a Recall or TSB regarding this issue?
I'll PM my VIN if needed.
Old 09-30-2012, 08:53 PM
dcjwlee's Avatar
I have a gut feeling that the brown wire is the power wire. We will see tomorrow.
Sigfreak, if you cannot get the harness off you can at least get the board that holds the bulbs off. It clicks off at two points very easily. Just make sure you don't pull too hard before removing the wires for the turn signals (remember which goes where).
Old 09-30-2012, 10:27 PM
Ben'sBenz's Avatar
2009 C300 Luxury P1 w/Multimedia, Arctic White
If i remember correctly, brown is supposed to be a ground wire.
Old 10-01-2012, 05:08 PM
E350 Sport/ML350RWD
Took it the dealership today. They replaced:
1 204-820-06-77 lamp carrier
1 211-545-03-28 plug
1 014-545-82-26 pin bushing
1 204-820-09-77 lamp carrier
Out of warranty almost a year- replaced at no cost
Woohoo!
Old 10-01-2012, 05:24 PM
sebydeleon's Avatar
merecedes c200k 2009
Same happend to me, and the dealer in Dominican Republic changed the parts damaged and the other side that was good was changed too. Everything under warranty an free
Great service!!!
Old 10-01-2012, 09:46 PM
dcjwlee's Avatar
Woohoo!
Wow, how much would it have cost otherwise? I couldn't get a loaner today, although they said absolutely to the lady in the CL behind me, so I tried to buy the parts but the guy at the parts desk... was zero help to put it nicely.
If you could scan and send me a copy of your invoice after blurring any sensitive info so I can show my dealer that it was covered free of cost... Did they goodwill it through corporate or something? Did your problem look like mine did in the frist post? The ground wire burned through the harness.
Old 10-02-2012, 05:21 AM
E350 Sport/ML350RWD
The plug is $40 each. The carrier is $26 each.
Old 10-02-2012, 05:24 PM
E350 Sport/ML350RWD
Old 10-02-2012, 06:19 PM
krazn1's Avatar
08 c300 sport 4matic
this is good to know... subscribed for future reference.
Old 10-02-2012, 09:26 PM
dcjwlee's Avatar
THANK YOU SO MUCH SIGFREAK. I will be printing this out and highlighting the portion mentioning GOOD WILL.
Old 10-02-2012, 09:54 PM
LandSeaAir's Avatar
2008 W204
SigFreak - Just wondering what kind of relationship you have with that dealership? I took my car to my local dealer once about a year ago for warranty repair, so I'm wondering if they would do this for me for free even if I haven't been a consistent customer.
I wish I could just buy the wiring harness cause right now on my car that's the only thing that's damaged.
Old 10-02-2012, 10:20 PM
dcjwlee's Avatar
^Ditto
The parts desk guy could not find the harness for me otherwise I would have replaced it myself. The bulb holder was easy to find. Going in on Thursday so I hope they goodwill this for me too!
Old 10-03-2012, 01:54 AM
E350 Sport/ML350RWD
The Service Advisor told me there would be charge for the repair. I asked to speak to the Service Manager and when I spoke to him- I advised it was a Safety Issue since my brake lights were working intermittently and he said it would be covered. It had also been noted in the computer that back in May/June 2011 I had received bulb-out error messages and when the dealership checked it- they were "checking" the harness because some of the connectors were "known" to come loose. Not sure if this helped.
Old 10-03-2012, 11:35 PM
dcjwlee's Avatar
As far as warranty goes you are over 50K miles and it has been five years since new car purchase so you are well out of warranty as far as the yearly limit, right?
Old 10-04-2012, 04:38 AM
E350 Sport/ML350RWD
Yes. And I do not have an extended warranty.
Old 10-07-2012, 07:04 PM
dcjwlee's Avatar
Sigfreak, I picked up a new connector at the stealer the other day. Did you notice it was shaped differently and does not fit all the way in?
Old 10-07-2012, 08:29 PM
E350 Sport/ML350RWD
That's probably why they replaced the lamp carrier too.
Old 10-07-2012, 10:21 PM
RLE
RLE's Avatar
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Four years. not five.
Old 10-12-2012, 12:49 PM
Headeater's Avatar
MB C300 2009
Dealer won't fix N/C :(
Any suggestions? They tell me I will have to pay approximately a "couple hundred" dollars. Been there done that with my first oil change, that isn't going to happen again. I notice on AkaSigFreak that it says "Performed Campaign 2012070002". When I had taken car in for service one time they fixed the trunk opening too fast and I was never aware of a "silent recall" to correct the issue but there was a similar campaign number listed, is there one for this and I just have to push even harder? 3.5 years old car and 74K miles but I don't know how long this has been burning up. Probably buy a fire extinguisher instead.
Old 10-12-2012, 09:57 PM
dcjwlee's Avatar
Unfortunately, one dealer's goodwill gesture doesn't set any kind of precedent for the others to follow.
However, a "couple hundred dollars" seems like an unlikely answer given that the parts are hardly over $50.... $35 for the lamp carrier, $15 for the harness, and like $1 for the pin that connects to the wire. It's an easy DIY and to be honest it shouldn't take a competent mechanic more than 30 minutes.
Most dealerships are more than happy to provide an itemized estimate and it seems like you should ask for one... I'm a little surprised that a SA would give such a vague answer.
Old 10-12-2012, 10:16 PM
Headeater's Avatar
MB C300 2009
Yeah, no question I will make the repair myself and just buy the parts. I have filed a formal complaint with the NHTSB and see where that goes. Just disappointed that this has to happen. Am buying an SLK250 in the spring as a summer car and will head over to Rochester NY to comparison shop. Previously I would have stayed at Mercedes Benz of Buffalo. All over a "couple hundred dollars".
Old 10-12-2012, 10:18 PM
dcjwlee's Avatar
Well if you like the sales team at buffalo and think you could get a better deal there you really shouldn't completely ditch mb buffalo. Maybe just find another service center?
Quick Reply: Tail light connector melted
