Tyre pressures - what are you running?
Old 09-25-2015, 05:47 PM
bensales's Avatar
Location: Her Majesty's Glorious Midlands of the United Kingdom of Great Britain
2015 C220 AMG Premium Plus Estate (S205)
Spurred on by my car moaning that the front tyre was low I checked my pressures.
2 bar in the front, and 2.1 in the back. That'll be a bit low then.
So, I dug out the manual (or rather open the app) and found the basic is 2.3 bar front and rear, or 2.7 front and 3.3 rear for fully loaded.
I compromised on 2.7 front and rear and reset the tyre pressure monitor to that. Ride doesn't seem to be any worse (thanks run-flats!) and I guess it'll save a couple of pennies on the fuel consumption but just wondered what others have set seeing as though, going by the manual, you can take these values and +/- 0.3 bar to them which is quite a range.
Old 09-25-2015, 07:29 PM
kenya's Avatar
2015 C400
I set mine to 38 PSI (or 2.6 bar assuming google is correct) all around. Just a little above the number listed in gas cover flap.
Old 09-25-2015, 10:32 PM
PeteInGilroy's Avatar
'18 GLC 300 4M/Air Suspension
32 P.S.I. all around.
Old 09-26-2015, 12:32 AM
2015C300's Avatar
C300, 911, 328i
42 front 46 rear. Love the gas mileage.
Old 09-26-2015, 09:44 AM
hpilot's Avatar
2015 C300
35 psi
Old 09-26-2015, 09:51 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
34 psi all around. Gas mileage is not impacted, handling is about the same, and the "thunk" over harsh pavement is less pronounced.
Old 09-26-2015, 10:37 AM
MASSC450's Avatar
2016 C450 AMG
36 psig all around...cold.
Old 09-26-2015, 10:42 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
19" run flat . 2,5 bar front and rear.
Old 09-27-2015, 01:14 PM
mbinnl's Avatar
S213 220D
220 Diesel: 2,7 bar front and 3.1 bar rear on cold wheels, saves 10% in fuel
Old 03-14-2016, 02:44 PM
akssdd's Avatar
2006 C230 Sport Sedan
Isn't it safe to assume that the car is going to perform how it should at the recommended spec in the manual/door sticker?
Old 03-15-2016, 11:33 AM
Spalato's Avatar
2015 c220cdi 7g avangarde
2,60 bar front and rear, 225/50-17 winter tyres. 220cdi w205.
Old 06-11-2016, 11:13 PM
ArmoE55's Avatar
2006 E55
Edit:Wrong thread sorry
Old 04-10-2018, 02:10 AM
mrplease's Avatar
Location: Born in California, moved to Hawaii, lived in Las Vegas, somehow ended up in Oklahoma City...
c-class
Old 04-10-2018, 12:29 PM
sr5959's Avatar
C400
39psi front, 45psi rear, 19@ staggered run flats.
car is handling and riding better since I did this.
Old 04-13-2018, 08:35 AM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
Just posted this in another thread about tire pressures and my experience.
My C300 came with 18 inch staggered runflats and has the same sticker under the gas flap. I ran the higher pressures although I rarely had a maximum load. Toward the end of the tires usable life, just under 20K miles, I noticed that the rears showed more wear in the center of the tires indicating the pressure was higher than it should be. I am now running non runflats and have lowered the rear pressures to 39-40 psi. Front tires did well at 39 psi.
Quick Reply: Tyre pressures - what are you running?
