C32 Star DAS How-to
Just print these pictures out in order and bring them to your local shop.
-10 Degree Fan Mod
Once the Star DAS is on and ready to go, run the software and choose "Cars".
Choose "C-Class / CLK"
Choose "203"
Hit "F3" to confirm the Series.
Choose "C32 AMG Kompressor" (Or your model if not C32)
Choose "Control Units"
Choose "Drive"
Press "F3" to confirm that you have read the safety notes
Choose "Control unit adaptations"
Choose "Correction programming"
Choose "Electric suction fan for engine or air conditioning"
Press "F5" until the temperture correction reaches 10 degrees
Choose "203"
Choose "Body"
Choose "Rear SAM"
Choose "National version of ATA function"
Select "Netherlands" from the drop down list and press "F3" to confirm
and thanks for the well written tutorial with pictures, it really helps Would the procedure be the same for the E55 except choosing the different model?
I can't imagine the face of the technician when I hand him a tutorial on how to do a specific job
Yes, should be the same. I can check later today if you want.
Heck....at least the alarm works on your car!!!! Gonna need to beg/praise/pay off wayne to play with star at the track to see what is failing on my alarm.
Thanks for the fan mod btw...
Mine has the fan mod, Netherlands setting, and an 86’d seat belt reminder. They merely make the car that much more pleasant to drive and operate. I always wear the belt when underway, just not when maneuvering around the driveway and garage…so don’t be hatin’.
Can I fly you out for some more tweaks and an ECU tune?!
