W203 Rear Sun Shade Won't go Down
2005 C230 Kompressor
I have 2005 C230. For most of the cars life I have driven around with the rear sun shade up. The other day I tried to retract is so I can clear the inside of the rear window and when I push the button on the dash it won't go down. Has anyone had this problem is it common? Of course the car just went off warranty (past 4 yrs) from sale date.
02 C32 AMG, 06 C230 Sport (Gone)
its not the parts its the labor cost as well. you have to disassemble the entire rear (interior) of your car, techs absolutley hate it, its a PITA!
This is a known issue with the C Class W203 any model it eventually fails over time, even with limited use.
If you hit the button and hear a humming in the sun shade, chances are its shot.
You can do it yourself, you just need patience and some basic tools, its a few bolts that holds the sun shade in place you can get to from in the trunk though the bottom of the rear speaker deck.
You also need to remove the two rear interior C pillar panels (be careful of the air bags), and the rear speaker deck, you will need to fold down (or remove the back) seats in order to get to bolts that hold the deck in which are located behind the seats.
According to the C Class W203 parts catalog - Blind, Roller Part# 203 810 03 20 is $1260.00
2012 C63
Mine had the opposit problem when I bought the car, it wouldn't open up. It didn't bother me because I never had a car that had one. The dealer took a thousand off the price, as they told me it would be too troublesome and expensive to fix.
Then one day I was in Bangkok and I noticed that my aunt's car has a blind in her E200k. I asked her driver if he ever had the problem with it. He told me from time to time it either fails to go down after being up for a while. What he did was to nudge the assembly around and it would then work. It may take a few goes before it works. When I got home I naturally had to try it out but doing the same and wouldn't you know, the darn thing started to work. It's working ever since for the past 5-6 months!
1 Post
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
look at the post by Darthbudice in the link below for specific steps. i purchased a new assembly from ebay for $350, and replaced the thing myself after my son(4) broke one of the arms off.
Removing the rear deck was difficult, but i took my time and completed the job in about 2.5 hours.
https://mbworld.org/forums/c-class-w...rear-deck.html
2016 E350 4Matic; 2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
The whole assembly becomes unfixed due to pressed fit plastic fasteners that don't hold up over time due to sun. Ironic, isn't it!
Anyway, after you get the deck off, you're going to need to drill holes and secure with new fasteners - preferably a nut and bolt rather than rivets.
does it help if you hit the centre console switch now and then just to excersize the electric motor?
I do this on my w202 AMG I hope it's a good thing doing this randomly?
Retrofitting this option is a bit-h accordin to my personal mechanic, I held a gun to his head and he installed this option on my car.
Never again I do this mod to another car he said.
PITA job as they say
05 C55 AMG
So I had a friend push the button while I was wiggling the sun shade and it did not go down. CRAP!
I can get access to the motor if I bend the sunshade down slighty. I am going to try to tap it with a hammer to vibrate it and maybe it will work.
05 C55 AMG
I fixed it!
If you bend the sunshade down, away from the window, you can have access to the motor. The motor has a metal rod that sticks out of it toward the driver side of the vehicle. I was able to get a small hammer down in there and gave the rod a couple of taps inward toward the motor.
I went to hit the button and the sun shade now works.
I fixed it!
you saved a few bux.
09 C63 AMG, 05 C55 AMG
I just dealt with this issue a few days ago. Long story short.
Option A: Push sunshade down until it goes down
Option B: Remove rear shelf and sunshade, and use torx to turn motor to close sunshade. Reassemble
* I removed the fuse for the assembly after I put it down *
I never use the rear sunshade, and useless if you have or plan on tinting your rear windows
you guys were lucky, mine won't budge. no clicking sound and absolutely no movement. Ill have to tackle this after some other projects
