Will '06 CLS500 wheels fit a C55?
Old 04-21-2014, 12:19 PM
TobiasMB's Avatar
10 C63/p31, 84 190/5.8L, 14 Audi Q5 TDI, 03 Suburban /8.1, 87 Porsche 944/358" 77 Ferrari 308 Dino
Will they fit without having to do any fender rolling? Has anyone done this upgrade as my rear tires will need replacing soon and found a set of nice CLS500 wheels locally for sale.
Thank you,
TobiasMB
Old 04-21-2014, 01:34 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
There is not enough info in your post to give you an answer.
Old 04-21-2014, 05:16 PM
TobiasMB's Avatar
To explain more clearly:
I have a 2005 C55 with the OEM AMG wheels, 7.5 & 8.5 X 18" wheels.
I just found a very nice set of 2006 CLS500 AMG wheels that are 8.5 & 9.5 X 18" wheels.
Will they fit my 2006 C55 without fender rolling?
Thank you....
Old 04-21-2014, 10:09 PM
Saaboteur's Avatar
eclectic assortment of cars
Best to figure out the offset on those CLS wheels. There always seems to be quite a variation even with stock wheels. That said, my recollection is that the offset might be too low, but you need to post up the specs.
Old 04-21-2014, 11:41 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
I believe TruTaing -- one of the forums moderators, has put CLS550 wheels on his W203. I would search some of his previous threads. I think it has been done, but you may have to use a different type or length of wheel bolt. You can try a PM to him also...
Old 04-22-2014, 12:34 AM
desired_speeds's Avatar
2007 SL55 AMG
yes they will fit if you put smaller tires and get new lug bolts. Are these the AMG package wheels or the other 5 spoke flower rims?
Old 04-22-2014, 10:24 AM
TobiasMB's Avatar
The C55 offsets are all 28mm. and the CLS500 are all 35mm.
What size smaller tires are recommended? The C55 OE tires, 225/40 and 245/35-18 don't leave many choices to choose from! Both sets are the non 5 spoke rims.
Thank you....
Old 07-25-2014, 11:48 AM
kimeran's Avatar
2012 C63 AMG, 1991 325iS. Ex: 2011 C63 P31
Would like to know, did the 35 offset fit on the car comfortably?
Old 07-25-2014, 06:51 PM
Moderator Alumni
TruTaing's Avatar
w203 m112
This cant be done! ;P
JK - All the info is on my photo album up in here. I also have 4piston front and rear calipers from the c32/55 and CL55...
Quick Reply: Will '06 CLS500 wheels fit a C55?
